mandy2016
Message 1 of 9
BT Infinity speed dropped ?
Hi I've noticed over the last few months or so my speeds have dropped and not sure why.
Downstream sync speed:  62.90 Mbps
Use to be around 67.00Mbps but now it's down to 62.90 Mbps. Nothing has changed here, everything is still as before when speeds was higher. Just wondering if there a long term problem?
I have re-booted the smarthub many times over the the few months. Speeds went up to around 33.??Mbps  It's not a huge problem, but wonder whats going on as I was lead to believe my speeds would be higher for the price.
If anyone at BT could look into this for me I would be grateful.
Many thanks in advance
M
8 REPLIES 8
albertj
Message 2 of 9
Re: BT Infinity speed dropped ?
How often is your hub restarted? If you reboot them too often, then it may slow down.
It can take time for your line to stable again.
Please press the thumbs up if you found my response useful and mark it as a solution if I resolved your query.
Sage
Sage
Message 3 of 9
@albertj Your post is very misleading.
Speed is not intentionally lowered in case of a problem with the line.
Too many reboots in a short time will trick DLM into thinking there is a problem.
@mandy2016
Could you post the connection stats from the hub.
HH6 Advanced settings/technical log/information.
HH5 Troubleshooting/helpdesk.
albertj
Message 4 of 9
Sorry, edited.
mandy2016
Message 5 of 9
I don't boot often, but since the problem maybe 2 or 3 times over a period for 7 plus weeks. System last re-booted System uptime:
7 Days, 9 Hours 2 Minutes ..
So details as requested below. Go easy I am new to all this.
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ62119395
Firmware version:
SG4B1000E01E
Firmware updated:
20-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
7 Days, 8 Hours 56 Minutes 0 Seconds
Data rate:
20.00 Mbps / 62.90 Mbps
Maximum data rate:
22061 / 63746
Noise margin:
6.9 dB / 3 dB
Line attenuation:
16.8 dB
Signal attenuation:
0 dB / 16.8 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
5320 MB Uploaded / 8430 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-GPZG
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-GPZG
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:19:1D:13
Software variant:
Boot loader:
7.33.1
mandy2016
Message 6 of 9
thanks for speedy reply, I do not often re-boot. I think BT re-boot the hub more than me when they are updating firm ware etc.
again thanks for the speedy reply.
Danathan
Message 7 of 9
67 to 62.9? Can you tell any difference? Or is this a typo? You suggest later speed went up  to 33.
Sage
Sage
Message 8 of 9
The connection stats do not show any problem, I'm willing to be those 4mbs come back over winter.
mandy2016
Message 9 of 9
Hi, can't really tell the difference it's just a  psychological thing, knowing you can or should be getting 67Mbps yet it's down to 62.90Mbps. It would just be nice to know what has caused it.
More like misleading than a typo.. It was 67Mbps for well since I first signed up with BT, It dropped to 62.00Mbps  and it's now at 62.90Mbps to be exact. Sorry a bit misleading as I never included the decimal point
Going back up in winter time? Hmm well maybe
Hope this clears things up
