tucker1984
Message 81 of 97
Re: BT Infinity speed drops to ~5Mbps during evenings
im now at 0.76mbps download, shocking altogether
greenspagbol
Message 82 of 97
Aaaaand 5 minutes later back to 5Mbps. Sheesh, this is getting beyond a joke.
quinnyboy
Newbie
Message 83 of 97
I too am having the problems mentioned in Portstewart.
Its very frustrating and its only coming on here that has made me realise it isnt my fault!
corky20
Message 84 of 97
Same. I always check the service status page when I have a problem but even now there's still nothing there about Northern Ireland. It would great if someone from BT could add a permanent message to the service status page to address the problem in Northern Ireland, it would save people from contacting BT and wasting both parties time.
Enceladus
Message 85 of 97
So it is 4pm and my speed seems to be normal. I am going to be vigilant and check it often to see if it drops the same way it has for the past week.
DaveNI1979
Expert
Message 86 of 97
Speeds seem to be holding up 2nite, been fine all morning and same after 6pm. Everyone elses working ok?
As you can see zero packet loss over 200 tests to bbc.co.uk. Fingers crossed its been fixed.
greenspagbol
Message 87 of 97
Just booted up Steam (which is when I noticed the drop originally) and everything seems fine. Fingers crossed. Smiley Wink
tucker1984
Message 88 of 97
unfortunately my speeds are just as bad as last night
http://www.speedtest.net/my-result/4091258601
Moderator
Moderator
Message 89 of 97
@Enceladus, @DaveNI1979, @greenspagbol,
Thanks for posting. Hopefully it’s all sorted but please keep us updated.
@tucker1984,
I think we’ll need to take a closer look at this for you if there is no improvement. Drop me an email with your details. You’ll get the ‘contact us’ link in my profile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Enceladus
Message 90 of 97
I have been running a speed test every 5 minutes and it hasn't dropped yet today!!!
Around 30 - 45 Mbps for me which is normal. Fingers crossed it stays that way.
