Message 11 of 14
Re: BT Infinity speed is awful! Apparently a hard engineering fault has appeared twice now in a week
Hi
I am sorry to see you are having problems
I suggest you contact the forum mods they should be able to get this problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
FabM
Message 12 of 14
Nope, how do you that becuase I've tried plugging the ethernet cable that goes into the homehub straight into the PC but that doesn't work!
Distinguished Guru
Message 13 of 14
Thats what you do, then set up a new internet connection using PPPOE in Network and Sharing center
If not, I'll try again 🙂
FabM
Message 14 of 14
I couldn't get that to work!
