Gaz929
Message 1 of 2
BT Infinity speed only 1-4mbps
Can anyone help me on here, I had BT Infinity installed on Tuesday 28th July and since then my internet speed has been a nightmare! It's actually slower now than it was when I had normal BT Broadband??? I spoke to them yesterday about it and changed the settings in my router "Hub 5" to 5ghz. It sped it up for an hour or so but today 08:00 which is not in peek times I'm back to 1-4mbps. It's actually faster if I switch off my wifi and use 3G on my phone! Surly this is not right????
1 REPLY
Message 2 of 2
Re: BT Infinity speed only 1-4mbps
can you post stats from hh5  go to troubleshooting then helpdesk post 1-12
run btspeedtester and when first test completes then run diagnostic test and post results  MUST be done wired
btspeedtester
have you turned off smart setup http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
have your split the networks http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
