Message 1 of 8
BT Infinity speeds
I have just been upgraded to bt infinity. My old suggested speeds for normal broadband were 15-20MBPS and i usually got around 18MBPS. Now i have fibre optic it says i should get between 40 and 54 MBPS but i can only get between 20 and 25MBPS. Do i need to wait at least a week for the speed to get up to what it should be?
7 REPLIES 7
Message 2 of 8
Re: BT Infinity speeds
can you post stats from your hub please
Message 3 of 8
Not 100% sure where I can find the stats but i hpe this is what you wanted. I just posted everything I could find.
Product name:
BT Hub 6A
Serial number:
+084319+NQ70251038
Firmware version:
SG4B10002244
Firmware updated:
14-Jun-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 0 Hours 45 Minutes 14 Seconds
Data rate:
9.13 kbps / 28.83 kbps
Maximum data rate:
9128 / 28832
Noise margin:
6.5 / 6.4
Line attenuation:
26.2
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
66 MB Uploaded / 1911 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-C52T
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-C52T
5 GHz wireless channel:
Smart (Channel 40)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A4:08:F5:85:F9:7F
Software variant:
Boot loader:
7.33.1
Connection status:
BT Broadband /
BT Infinity /
BT Infinity 3 and 4:
BT Infinity
Firmware version:
SG4B10002244
Firmware updated:
14-Jun-2017
 Serial number:
+084319+NQ70251038
 Downstream sync speed:
28.83 Mbps
 Upstream sync speed:
9.13 Mbps
 Network uptime:
0 Days, 0 Hours 49 Minutes
System uptime:
0 Days, 0 Hours 51 Minutes
BT Wi-fi status:
Active
Message 4 of 8
I have actually noticed, after doing some research online, that when i plug my hub into the test socket on the master socket I get around 40MBps which is what i should be getting. How do i get similar speeds on all the sockets in the house?
Sage
Message 5 of 8
It sounds like you have "star wiring" which is a killer for VDSL (Infinity). When you connect to the test socket do your extentions still work?
Message 6 of 8
When I connect to the test socket, i have to take off the front of the master socket which then disconnects all of the other sockets around the house.
Sage
Message 7 of 8
Are the stats you posted earlier taken when connected to the test socket?
Message 8 of 8
no. they are taken connected to an extension socket in the room the router usually sits in.
