Distinguished Guru
Message 11 of 16
Re: BT Infinity using TALK TALK IP, Gateway and DNS servers!
Not sure if it would be incorrectly wired to a talk talk port as the homehub would not have authenticated with a non BT line
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 12 of 16
I am not sure that it still applies to VDSL, the same as it did with ADSL.
The issue of course, could simply be that the circuit has been incorrectly built at the gateway router.
clam1952
Message 13 of 16
All up and running properly with BT IPs, plus speed has gone up from 45Mbps to 51Mbps.
Thanks for the assistance.
Moderator
Moderator
Message 14 of 16
@clam1952  Brilliant I'm glad that's all sorted for you now. According to the engineer notes your line was incorrectly connected in the cabinet.
Distinguished Guru
Message 15 of 16
Do you know what the problem was and how it was solved?
Message 16 of 16
@Devon_Dave
See the above post by the moderator for the answer.
