Sage
Sage
Message 11 of 51
Re: BT Infinity won't connect to pcspecialist forum, but BTWiFi will. DNS issue or something else?
@dnpark38 wrote:
I'm a PCS customer and forum member and just now tried my Favorite link for the forum and I get redirected to their homepage where I clicked the forum link this fails so I feel PCS have a problem.
I can log in to my account just the forum I can't access.
If it were a forum problem then it would be the same for everyone. Some of us can access the forum easily. That's why I suspect a DNS issue.
Message 12 of 51
There seems to be quite a few DNS issues. I had somone who could not access my website, an when I checked the IP address, it was coming from some old BT Corporate legacy equipment. They were having lots of DNS issues, and when they restarted their home hub, the IP address changed to a normal BT CentralPlus one.
@Fellwalker what message do you see when you select this link BT Broadband check
dnpark38
Message 13 of 51
So does that mean a BT internet problem?
You are connected to BT Residential Broadband
Message 14 of 51
They both register as btcentralplus.com, different ranges, but correct.
It has to be a routing issue somewhere. Restarting the home hub should give you a different public IP address, and possibly a better route.
Fellwalker
Message 15 of 51
it shows the same however I am connected to the hub.
The SmartHub shows
Primary DNS:
81.139.56.100
Secondary DNS:
81.139.57.100
To err is human, but to really mess it up requires a computer
dnpark38
Message 16 of 51
Yes a restart as made both my Favorite and Forum link on the PCS homepage work, thanks, hope OP is ok too.
Fellwalker
Message 17 of 51
I wish I knew. It is a computer problem, so I am never convinced it will solved as such, merely temporarily worked around.  That has been my experience over 44 years of the delightful things, since I first came across PL/1 at University.
Perhaps because I have connected to the forum by changing to BTWiFi, it now seems to be happy to work in the forum  back on my main BTHub6 connection.  I've not rebooted.
Fellwalker
Message 18 of 51
Nope!
I've tried to return to the PCSpecialist forum today. 404 in all browsers. In between times I have rebooted the laptop.
BUT if I change my wifi connection to BT WiiFi-with-fon, it works perfectly.
It must be a BT problem.
Message 19 of 51
Did you restart the home hub to get a different public IP address?
It could be something within the home hub internal routing which is corrupted, so a factory reset of the home hub may help.
dnpark38
Message 20 of 51
I have advised PCS that I have this problem with them.
