Message 1 of 6
BT Infinity
I've just had BT Infinity installed but the only socket in the house is in the hallway. I can either pay for an engineer to move the socket or I can purchase the Broadband Extended 600 kit. Can anyone tell me if I will lose significant download speed by going with the cheaper kit rather than move the socket ?
5 REPLIES 5
Message 2 of 6
Re: BT Infinity
It's an unanswerable question.
The only way to know is to install it.
Message 3 of 6
Re: BT Infinity
Cheers, just wondered if anyone had used the kit and found it worthwhile rather than the time and expense of an engineer.
Message 4 of 6
Re: BT Infinity
The broadband extenders usually have a better throughput than you are going to get from a normal BT Infinity connection, so they would be the cheapest option.
Message 5 of 6
Re: BT Infinity
Ideal, thanks
Message 6 of 6
Re: BT Infinity
My daughter used these on a 38Mbs Infinity 1 connection, and there is no noticable drop in speed.
http://www.shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
