Message 21 of 25
Re: BT Plus Speed
When it cools down a bit, the simplest thing to do is to identify the incoming cable and the cable to the master socket and disconnect/ cut the rest. Phone wiring is extremely simple, it just uses 2 wires that are not polarity conscious.
Message 22 of 25
Re: BT Plus Speed
the extension cables are owners problem  openreach would probably just disconnect the extensions and leave the main connection to master socket.  extensions should not be connected to the junction box although many people did that for convenience when setting up phone extensions  this works fine but the star wiring is a killer for broadband
Message 23 of 25
Re: BT Plus Speed
OK Thanks. If tomorrow's better I can take a look then.
Message 24 of 25
Re: BT Plus Speed
Just to close this. Openreach came and did as you said they would, disconnecting all the secondary sockets, other than the one they converted to the main socket replacing the one in the loft. Speed is now much better.
So thanks to those who advised and helped me sort this out.
Moderator
Moderator
Message 25 of 25
Re: BT Plus Speed
Hi @jhrowley,
Thank you for taking the time to post back.
Cheers
PaddyB
