coog
Message 1 of 6
BT Smart Hub and Fibre to the home
I have the new smart hub comming but see it does not have the red connector that connects to the wall
How do I connect
I have a white box (modem ?) and battery back up - this is where the fibre cable goes to and where I connect the red cable to the current home hub
I have read the new smart hub instructions and it says connect straight to master socket which currently has nothing connected to it
Do I disconnect and remove the modem and battery backup stuff ?
5 REPLIES 5
Message 2 of 6
Re: BT Smart Hub and Fibre to the home
There are two types of smart hub. One for FTTC and one for FTTP. The one you want/need has the correct connection.
See message 60 from the moderator on this thread.
https://community.bt.com/t5/Connected-Devices-Other/Can-I-use-separate-modem-with-new-BT-Smart-Hub/t...
coog
Message 3 of 6
I hope they send the correct one !
Of all the pages and pics and install guides I looked at none mentioned 2 diffrent smart hubs
Message 4 of 6
That's BT for you. If there is a complicated way of doing things and not telling the customer they will find it!
Message 5 of 6
@coog wrote:
http://bt.custhelp.com/app/answers/detail/a_id/10477/~/user-guides-for-bt-broadband-and-bt-infinity-... has different guides for FTTP and FTTC
coog
Message 6 of 6
Thank you
I missesd that !
