Message 1 of 11
BT Smart hub resetting
It seems my BT Smart Hub  resets every 14 days, would this cause a problem with my download speeds ?
My old isp i could get around 62mpbs but most im getting with BT is around 53, i have also noticed my uploads speed used to max out at 19 not its 15
his is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
Firmware version:
SG4B1000B540
Firmware updated:
20-Apr-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
7 Days, 13 Hours 49 Minutes 1 Seconds
Data rate:
16.88 Mbps / 54.73 Mbps
Maximum data rate:
17185 / 66581
Noise margin:
6.3 dB / 6.3 dB
Line attenuation:
19.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
25857 MB Uploaded / 78709 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6
5 GHz wireless channel:
Channel 36
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
Software variant:
Boot loader:
7.33.1
10 REPLIES 10
Message 2 of 11
Re: BT Smart hub resetting
there are numerous posts about the hub resetting every 14 days but it never normally causes and speed problems  I had the problem for over a year and never had any problem with my speed.  the hub would drop conenction and re-connect within a minute or so at same speed and noise margin
however if your hub is dropping more frequently or you were manually resetting to try and improve your conenction speed then that could have an adverse affect on your conenction speed
Message 3 of 11
Message 4 of 11
Thanks, no i havent touched the hub at all, it seems odd that my speed especially upload has reduced and i cant connect as fast as my old isp
Message 5 of 11
Unfortunately you like me are on an ECI cab so at present there is no G.INP to help improve your speed from current level
Recognised Expert
Message 6 of 11
Your data rate is only 54.73 down but the max rate is  66.58 which does seem to suggest you may have had a problem sometime so there is a possibility your speed may increase sometime in the future. Normally the 14 day reboot has no impact but it could possibly mean that dlm still treats it as a minor fault on the line and isn't increasing the down speed - not certain if this is the case and maybe a Sage will know more.
Message 7 of 11
@conrad
As I posted already I never had any affect on my connection speed due to The 14 day resetting hub problem which lasted for about 1 year
however if other drops or manual resets or power cuts then that is something different any could have connection problems
Message 8 of 11
there has not been any power cuts, the max speed mentioned is 66 on my hub  , so does that mean i should get somewhere  near that ? as i said my old isp i used to get over 60+ regually
is there any way to improve my speed ?
thanks
Message 9 of 11
Your connection speed may move nearer your attainable speed but all you can do is maintain a stable connection apart from 14 day reset and see if DLM increases the speed. There is nothing you can do to speed it up
Message 10 of 11
thank you
