tomwalsh77
Message 11 of 13
Re: BT SmartHub keeps dropping internet connection
I have nothing else plugged in to the phone socket. We don't use a landline so no phones are connected, should I still try the test socket or would it be pointless trying it?
Message 12 of 13
Using the test socket will eliminate your faceplate as the problem. They do not work forever
if still getting problem in test socket and quiet line test ok then try CS and see if you can get a new hub
tomwalsh77
Message 13 of 13
Ok thanks for your help. :smileyhappy:
