Message 1 of 4
BT Telephone Plug to RJ11 Cable
what is the purpose of the BT Telephone Plug to RJ11 Cable?
Is it to bypass a adsl filter and connect straight to the internet with no filter in the way? I guess this is fine if you have no telephones and are on Sogea?
3 REPLIES 3
Message 2 of 4
If you have no telephones in the house, and only broadband on sogea, I assume this is fine to use a BT Telephone Plug to RJ11 Cable to bypass the microfilters?
Message 3 of 4
Re: BT Telephone Plug to RJ11 Cable
Technically the filter is just for the old PSTN phone-side of things.  The internet connection, (and Digital Voice), do not need it.  The only reason for continuing to use the filter is if you don’t have a BT to RJ11  lead and so need the RJ11 socket it provides.
Message 4 of 4
Yeah, if you’re on SOGEA you don’t need an ADSL Filter and or SSFP.
