GloryHornet1
Message 11 of 15
Re: BT UK Ireland Support Numbers?
Around the 26mbps download, but was expexting more, anything up to 32mbps
GloryHornet1
Message 12 of 15
How long would you wait from this point onwards?
pippincp
Sage
Message 13 of 15
Your router stats do not appear to show a problem so once G.INP kicks in again then you should get your previous speeds back.
As said earlier this can take up to 14 days.
Why would you expect to get any more than previous? You will only ever get what your line is capable of no matter which package (or package name) you are on.
GloryHornet1
Message 14 of 15
After the initial line speed test and looking at the upgrade the order spec said and estimated: We estimate your download speed will be between 25Mbps and 35Mbps so I was expecting something in the high twenties rather than the 25mbps max I previously had. Now its at 21mbps. They dont explain you may have to wait a fortnight to see any increase in speed, thus causing frustration and resentment.
pippincp
Sage
Message 15 of 15
TBH I think no-one realised that the line would be reset. We certainly didn't on here until other users started reporting the problem.
