Mittal254
Newbie
Message 1 of 3
BT Ultrafast third party modem and Router
Hey all,
I have recently had Ultrafast 2 installed. I have bought a third party modem to bridge to my router. However I can't seem to get an internet connection on this modem. It is g.fast compatible here is the link to the particular model http://www.zisacom.com/c/default/pageId/5541dd482034da9f368b45ce/articleId/59439b639ccde2d02b4a7810
From what I can see there shouldn't be anything preventing a connection being made on the modem. There are a lot of advanced settings on this device so was wondering if anyone knew if I could set this up to get a connection. Or is it the case that BT use proprietary technology and only the Smart Hub X will work on Ultrafast?
2 REPLIES 2
mattanorak
Message 2 of 3
Re: BT Ultrafast third party modem and Router
Hi,
Interested to see if you managed to get it to work and how much the modem set you back. I have a Huawei MT992, but always like having a spare just in case (that isn’t the Home Hub!)
kisel1
Newbie
Message 3 of 3
Hello, have you been able to configure this moded for Ultrafast 2? And if so - where can I purchase one? Thank you!
