Message 1 of 35
BT Vectoring and G.Fast, OMG
So Vectoring is noise cancellation to increase your broadband speed from the lines being bunched together, And G. Fast is bringing the fibre all the way to the telegraph pole then using copper from the pole to your home (Correct me if i'm wrong).
Would there be a need for vectoring if BT done G. Fast, because the lines would not be bunched together, they would be separate coming out from the pole?
Does anyone know when Vectoring or G. Fast will actually happen?
http://www.bbc.co.uk/news/technology-29360758
http://recombu.com/digital/news/bt-gfast-gigabit-broadband-trials-achieve-700mbps-downloads
34 REPLIES 34
conrad
Recognised Expert
Message 2 of 35
Re: BT Vectoring and G.Fast, OMG
See this link where there is a bit about the drastic speed reduction if vectoring isn't present http://www.huawei.com/ilink/en/solutions/broader-smarter/morematerial-b/HW_278065
conrad
Recognised Expert
Message 3 of 35
From whats been posted on the web it may be commercially available by the end of 2015 but even if BT went ahead with its implementation plans it could be several years before people could subscribe to G.fast
dfenceman
Expert
Message 4 of 35
Hi GeekOfBroadband,
You may find this of interest :- http://www.increasebroadbandspeed.co.uk/2014/vectoring-crosstalk-crisis
Best regards,
dfenceman
chris6273
Recognised Expert
Message 5 of 35
Vectoring on FTTC will likely still go ahead if that's what you mean - It's little more than a software change on the DSLAMs.
As for G.Fast vectoring - Some poles I've seen are very heavily populated - I guess it depends what research ends up being done in the BT Labs.
To be honest I'd be very surprised if Vectoring on G.Fast isn't used from the beginning if it's available. It's much easier to install a system all set up than add things to it later which were readily available from before the date of install.
As for Vectoring on FTTC hopefully soon! We've seen almost a 40Mbps drop in attainable rate since the FTTC install which is quite unsettling.
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
Checked2013
Expert
Message 6 of 35
I think if it was only just a software change then it would have been implemented by now on FTTC. Do you have any info on this?
Message 7 of 35
OR are still trailing vectoring no decision on when it will be implemented yet
chris6273
Recognised Expert
Message 8 of 35
It's a firmware update on the FTTC DSLAM that's required.
There was some talk of the ECI DSLAMs in use not supporting Vectoring but a fellow forum user pointed out the ones Openreach use actually do which was surprising and comforting.
It's in field trials at the moment with OR (Has been for some time) so hopefully it will be released sometime in the near future.
As for if it was just a software change, it is. However I expect OR are testing all aspects of it including its full capability including speed and stability enhancements in densely populated cabinets which takes time.
Deathtrap3000
Recognised Expert
Message 9 of 35
They are supposedly setting up a lab to trial g.fast and fttdp (fibre to the distribution point) which could bring fibre to the pole or footway box and use copper the rest of the way. Seems pointless to bring fibre that far and not go full fttp.
G.fast uses vectoring as well as much higher frequencies to achieve high speeds, so that needs to work properly first before they can go any further.
Checked2013
Expert
Message 10 of 35
I was under the impression that during the current trials that ASIC vector engines were being used which meant that some of the hardware has to be replaced in the cabinets. It's one of the reasons why it's taking weeks to enable a cabinet for vectoring and not just an over night job.
