Hi
Is it possible for me to check SVLAN status at my exchange anywhere?
My connection has recently been poor at peak times (15-35mbps), up until Christmas speeds have been consistantly around 50mbps.
I can only assume that as more and more people are connected to the SVLAN speeds are going to continually suffer?
Cheers
Mark
Hi @markr1977
Welcome and thanks for your post!
What exchange are you connected to? Post back and let me know. I'm here until 21:00 so if you get back after that, one of the other mods will check this for you in the morning.
If you're quick I can check for you now
Cheers,
Robbie
Hi Robbie
Thanks for the fast reply.
My exchange is Drayton.
Cheers
Hi @markr1977
I've had a look at this and nothing obvious stands out.
Can you run >>this speed test<< when you feel the speed is performing poorly and post a screenshot?
Cheers,
Robbie
