73henny
Message 1 of 23
BT WiFi
Hi. I've infinity 1 which is working well, however I wonder if the BT wifi is reserving some of my bandwidth? The reason I ask is I have a 4K tv with Amazon prime and should comfortably be able to stream 4K. My connection speed is about 24 Mbps and Amazon say 20 should be plenty. Does BT wifi reserve some bandwidth that I can't use?
22 REPLIES 22
Message 2 of 23
Re: BT WiFi
No, there is nothing reserved. Users of the hotspot simply use whatever is remaining, you always get priority.
73henny
Message 3 of 23
Re: BT WiFi
Ok thanks. I'll have to look elsewhere for the source of my problem.
Colin_London
Recognised Expert
Message 4 of 23
Re: BT WiFi
If you are reading your connection speed from your Homehub management page the first thing to be aware of is that your maximum throughput is 96.8% of that figure. This is your 'IP profile'.
Next when Netflix say 20Mbps should be plenty they are talking about a constant throughput that never falls below 20Mbps. Your throughout can vary due to network congestion or factors like interference on your line.
For an application that requires a constant minimum of 20Mbps I'm afraid your connection is borderline.
One final thing - you do use an Ethernet cable to connect your TV to your hub don't you?
73henny
Message 5 of 23
Re: BT WiFi
The TV is connected wirelessly. My hub is downstairs where the main BT socket is and the TV is upstairs in our lounge. What I can't understand though is why it worked perfectly when I got the TV a month ago and there's been no drop off in speed?
Colin_London
Recognised Expert
Message 6 of 23
Re: BT WiFi
New source of Wireless interference? It is better to use powerline adapters than wifi for High Bandwidth TV because wifi performance cannot be guaranteed.
73henny
Message 7 of 23
Re: BT WiFi
Thanks for your help.
I'm not aware of anything that could cause any interference. We've not added anything since getting the tv. It has a browser, so I wonder if a speed test on there would give an accurate reading for its connection speed?
Message 8 of 23
Re: BT WiFi
Have you tried all 13 wireless channels that are available on the home hub, just in case the three "smart" channels are all congested?
You will have to turn smart wireless off, and select each channel manually.
73henny
Message 9 of 23
Re: BT WiFi
I've just run the test through the tv's browser and only got 8 Mbps! Yet my iPhone app has come back with 27 Mbps. Why would it be so different?
Colin_London
Recognised Expert
Message 10 of 23
Re: BT WiFi
Because your TV has a rubbish wifi adapter / antenna?
or if you have a plug in adapter, it is behind the screen which acts as a big shield against the wifi signal.
