Newbie
Message 1 of 6
BT broadband painfully slow
I don't know what is wrong with my broadband connection today but it's ridiculously slow. I started downloading a file that is 137 MB in size about 10 minutes ago and I'm still only 46 MB into the download. I did a broadband speed check and said I was downloading at 29 MB. Not sure what is going on but it's running as slow as an asthmatic ant, carrying heavy shopping
5 REPLIES 5
Message 2 of 6
Re: BT broadband painfully slow
@Penn
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Can you please provide the connection information from the home hub?
If you are using the BT Smart hub you can get your connection stats by, Opening a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log’
Can you also provide the results from this test.
https://speedtest.btwholesale.com/
This must be done with a computer connected to the home hub using a direct Ethernet cable.
Newbie
Message 3 of 6
sorry, exactly what specific bits of information are you looking for? I've opened up my Smart Hub and am looking in the technical log section.
Message 4 of 6
Connection speeds, noise margins.
Message 5 of 6
it's actually the technical log information is the heading
Newbie
Message 6 of 6
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 78.5 55.6 20 18.5 49.5 Available Available --
VDSL Range B (Impacted) 76.2 50.9 20 16.6 43.6 Available Available --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
ADSL Availability Date
WBC SOADSL Availability Date
Left in Jumper
WBC ADSL 2+ Up to 7.5 -- 6.5 to 8.5 Available Available Yes
WBC ADSL 2+ Annex M Up to 7.5 Up to 1 6.5 to 8.5 Available Available Yes
ADSL Max Up to 5.5 -- 4.5 to 6.5 Available Available --
WBC Fixed Rate 2 -- -- Available Available Yes
Fixed Rate 2 -- -- Available -- --
Observed Speeds
VDSL
Max Observed Downstream Speed (Mbps) 39.99
Max Upstream Observed Speed (Mbps) 8.49
Observed Date 2020-03-30
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap Y
VRI N
NTEFaceplate N
Last Test Date 24-03-2020
