beejar
Message 11 of 12
Re: BT changed max obtainable speeds, Infinity 2 15Mbit loss
Just to follow up to this, we had an engineer visit who changed the vDSL faceplate to a Mk4 from the Mk3 we had previously. They also replaced some of the line between the house and the cabinet which has brought the noise margin down to around 7dB for the downlink. The router now has a link speed of 68Mbit.
Thanks for all those that helped.
Moderator
Moderator
Message 12 of 12
Hi @beejar
Thanks for posting back to let the community know the outcome of your fault.
I have marked your post as the solution also Smiley Happy
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
