hashemfouad
Message 11 of 19
Re: BT connection
I am with BT broadband since 3/2019, can i send you my number to check that?
Matt-S
Moderator-Retired
Message 12 of 19
Re: BT connection
Hi hashemfouad,
Welcome back to the Community and thanks for taking the time to post.
Are you a FTTP customer by any chance?
Matt
hashemfouad
Message 13 of 19
Re: BT connection
Hello
Yes i am
pippincp
Message 14 of 19
Re: BT connection
Ring the FTTP team on 0800 587 4787. The mods here cannot deal with FTTP issues.
hashemfouad
Message 15 of 19
Re: BT connection
ok noted, will do
pippincp
Message 16 of 19
Re: BT connection
Let us know how you get on.
hashemfouad
Message 17 of 19
Re: BT connection
Hi
Yesterday i called BT customer services, and i was very disappointed, they said that my connection is working fine, and open-reach technician reported that connection is working, however, we showed him that specific websites do not open, or opens and dosent download pictures, like Instagram, Pintrest, Whats-app, in addition that X Box shows connected to Wifi, but when my son starts the game it is actually not connected.
They said they cannot do anything about it because no faults are visible, and they closed the ticket.
Now, i tried something i read on google, to install a free VPN, on mobile phones, and when i did that, it worked and apps like instagram and whatsapp, Snapchat worked properly!!! I am not an expert, so i dont know what is the exact problem. Still i have the major problem that i cannot connect my work laptop & the Xbox!!
Any ideas how it can be solved?
Thank you all
imjolly
Message 18 of 19
Re: BT connection
do you have web protect enabled?  if so have you tried with it disabled to see if that solves the problem
hashemfouad
Message 19 of 19
Re: BT connection
We have tried to disable, web protection, parental controls, but both didnt work!
