L3
Message 1 of 28
BT fibre low speeds
27 REPLIES 27
Message 2 of 28
Re: BT fibre low speeds
You need to post hub/router stats
dslchecker results?
quiet line test?
L3
Message 3 of 28
Re: BT fibre
im on infinity upto 52 meg but my router is showing a low speed of 34998 is this banded again.
But max rate in router can get high 40s seen 46-47. I used to max out the adsl checker stats when first had infinity always hittng 50s
its not the first time been banded, whats going on BT?
tp link stats
Current Rate (Kbps)
6666
34998
Max Rate (Kbps)
6666
42898
SNR Margin (dB)
6
10
Line Attenuation (dB)
22.6
22.7
Errors (Pkts)
2081
54121
adsl checker
Message 4 of 28
Re: BT fibre
the important information about internet connection time not system uptime is missing from the information you posted.  are you having problems with your internet dropping or manual resets or both as your conenction speed does look in banded profile.  this would only happen with drops in connection
what about quiet line test?
Moderator
Moderator
Message 5 of 28
Re: BT fibre
Hi @L3,
Have you tried the quiet line test as suggested? Please, could your reply with the information @imjolly has requested?
This will help to give us an indication of what can be done to improve the speed of your connection.
PaddyB
L3
Message 6 of 28
Re: BT fibre
Did the bt wholesale speed test thing
Download ip profile 30
Upload ip profile 10.
Did line test thing just little hissing, not crackly.
L3
Message 7 of 28
Re: BT fibre
The banding was  39998 and the now 34998.
Why am I keep getting banded, and getting poor speeds.
This below is router uptime of 12 days
Current Rate (Kbps)Max Rate (Kbps)SNR Margin (dB)Line Attenuation (dB)Errors (Pkts)
666634998
666645739
5.711.9
22.622.7
363456086
Message 8 of 28
Re: BT fibre
Can you post full set of router/hub stats including internet connection time  12hrs  looks more like system uptime. Banding only normally happens with unstable connections whether that is router dropping internet connection or manual resets trying to improve connection speed or a combination of both
if you can hear any noise on quiet line test with corded phone then you have a line problem and need to report a phone fault to 151. However I would check quiet line test from test socket to ensure problem still exists and not caused by your internal wiring and avoid the £85 callout charge
L3
Message 9 of 28
Re: BT fibre
I have no internal wiring router tp link is in living room direct to a BT face plate the new rounded version.  I have home plugs sending ethernet upstairs
Time:12 day(s) 06:14:12
DSL
Line Status:Connected
DSL Modulation Type:VDSL2
Annex Type:Annex A/B/L/M
  Upstream DownstreamCurrent Rate (Kbps)Max Rate (Kbps)SNR Margin (dB)Line Attenuation (dB)Errors (Pkts)
666634998
666644576
5.811.4
22.622.7
367456103
Message 10 of 28
Re: BT fibre
from memory the tplink shows system time not internet connection time
