drewdrew
Newbie
Message 1 of 2
BT fibre speed issues
I have fibre the one with a theoretical speeds up to 300 mbps. The house is a new build and I have not until recently looked at the speeds I'm getting. They vary from 45 mbps to 100 mbps via wireless.
I did a speed test via the BT website and they confirmed 300 mbps to my modem was recorded. So something is going wrong my end of things. A friend said that you should not use cat5 cables which came with the router as they can only handle up to mbps but I'm not so sure that right.
I would be very grateful for some ideas of what to check / what the problem could be.
1 REPLY 1
Message 2 of 2
Re: BT fibre speed issues
No ISP will guarantee wireless speeds, there are too many variables.
Try splitting the 2.4G and 5G bands and try setting the channels manually to get a channel with less interference.
Your friend is talking absolute nonsense about cat5 cables.
