Message 1 of 6
BT hub 2 fibre plus 3 disks
Having issues with Wi-Fi speed not the internet speed into the house.
500 M/bit as supposed.
mobile devices varies from 20 to 130.
ethernet devices are at speed 500 via switches. Hue, and Sonos.
sky is in the house.
I cannot see how to split the 2.4 and 5.
any help would be appreciated.
thanks.
5 REPLIES 5
Message 2 of 6
Re: BT hub 2 fibre plus 3 disks
Unfortunately with the smarthub2 you can't split frequencies, all you can do is turn 5Ghz or 2.4Ghz off.
Message 3 of 6
Oh thanks.
I hope that changes.
or have to change the hub.
the service to home is great.
thanks again.
Message 4 of 6
It won't change, it is deliberate.
Message 5 of 6
Really why?
seems a third party hub might be required.
thanks
Message 6 of 6
Thanks. That’s a pity
