Cobbmeister
Message 1 of 19
BT infinity 1 Speeds on BT Infinity 2 - 74Mb actual dropped to around 34Mb.
A few months ago we purchased BT Infinity 2. The Infinity checker online stated that we would receive around a data speed of 76Mb. For the first two weeks it was hanging around 74Mb and was quite chuffed. After that I didn't bother checking for a while, until one day when I just thought I would. It had dropped down to somewhere 56Mb and i had posted at the time.
 It has now dropped to 34Mb at the lowest I've seen, and some usages of BT Infinity have been buffering.
I have run the various test below. Any help appretiated.
Line Noise Check Results - Slight constant crackle, although no other background noise.
Area Problems (Service Status) - None reportd by BT
BT Home Hub 5 Router Stats:
1. Product name:BT Home Hub
2. Serial number:+068543+NQ50533966
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 24/06/15
4. Board version:BT Hub 5A
5. DSL uptime:2 days, 01:24:22
6. Data rate:19999 / 38274
7. Maximum data rate:21161 / 60033
8. Noise margin:6.6 / 11.9
9. Line attenuation:24.1 / 15.7
10. Signal attenuation:24.4 / 15.7
11. Data sent/received:2.6 GB / 81.5 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-MTS6
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 300 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-MTS6
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Disabled
23. MAC Address:44:e9:dd:6b:7f:e6
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:
1.0.0
DSL Checker Results
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
  HighLowHighLow
FTTC Range A (Clean)8075.12020--Available
FTTC Range B (Impacted)8073.42019--Available
WBC ADSL 2+Up to 6--4 to 8Available
WBC ADSL 2+ Annex MUp to 6Up to 14 to 8Available
ADSL MaxUp to 5--3.5 to 7.5Available
WBC Fixed Rate2 ----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
 Speedtest.BTWholesale.com Test
Downolad Speed: 35.94 Mbps
IP Profile: 37.05 Mbps
Upload 16.20 Mbps
Upstream Rate IP Profile: 20.0 Mbps
Ping latency (ms) 25.38
18 REPLIES 18
Message 2 of 19
Re: BT infinity 1 Speeds on BT Infinity 2 - 74Mb actual dropped to around 34Mb.
you need to report the line noise on 151 with no mention of broadband in the call
Cobbmeister
Message 3 of 19
Hi John,
I have managed to get hold of a working wired telephone handset, just to test the line before I call BT and get them to come out. The line seems clear now. The previous handest was cordless and could have been interference from another source. Looking at the other tests, do you have any other ideas for this speed drop?
Message 4 of 19
Connection time is only 2+days so it may be if you have not been checking that your router has been dropping connection which would account for the higher than normal 6db noise margin
have you tried using the test socket with a new filter and see if that helps improve your connection. You may have a SSFP but using test socket eliminates a problem with the SSFP and also your internal wiring
Cobbmeister
Message 5 of 19
Hi Imjolly,
 The conenction time of 2 Days is me. I have just checked the HH5 log and there are no issues with any connection time. I have also checked the test socket and tried a new filter. Also re-run the tests and the results are exactly the same as the ones posted below.
(SSFP)
Just for clarification I have the I-Plate version and have microfilter at socket points around the house. The test socket is behind the I-Plate.
Message 6 of 19
Sorry but if no drops in connection apart from your reset then how did you get a lower speed as you would need a drop in connection before reconnecting at lower speed
posting router stats from test socket would help as that should be your best connection. If still low And no change in noise margin with quiet line test ok then you need engineer visit
Sage
Sage
Message 7 of 19
@Cobbmeister wrote:
Hi Imjolly,
If by "you" you mean you have been resetting the Hub then STOP! VDSL is different to ADSL and doesn't like resets too often. It could cause DLM to intervene and raise your noise margin and/or put you on interleaving.
Cobbmeister
Message 8 of 19
pippincp / imjolly,
 I meant "Me" as not the HH5. I leave the HH5 alone as much as I can. We had a power cut here 2 days ago, which has caused more than likely caused the reset of the connection time.
Not sure if I was looking at the correct info on the log but have noticed the following:
20:02:32, 18 Sep.
( 145.180000) PPPoE is up -​ Down Rate=38274000Kbps, Up Rate=19999000Kbps; SNR Margin Down=12.2dB, Up=7.2dB
12:41:19, 06 Sep.(1015562.600000) PPPoE is up -​ Down Rate=38274000Kbps, Up Rate=18333000Kbps; SNR Margin Down=12.0dB, Up=6.1dB
06:03:19, 05 Sep.(905284.920000) PPPoE is up -​ Down Rate=38274000Kbps, Up Rate=18011000Kbps; SNR Margin Down=12.1dB, Up=6.0dB
12:36:04, 04 Sep.(842451.940000) PPPoE is up -​ Down Rate=42101000Kbps, Up Rate=18524000Kbps; SNR Margin Down=10.7dB, Up=6.0dB
06:22:18, 03 Sep.(733628.500000) PPPoE is up -​ Down Rate=42101000Kbps, Up Rate=17975000Kbps; SNR Margin Down=10.8dB, Up=6.0dB
08:37:09, 02 Sep.(655320.970000) PPPoE is up -​ Down Rate=46901000Kbps, Up Rate=17945000Kbps; SNR Margin Down=9.0dB, Up=6.0dB
05:42:07, 28 Aug.(212830.600000) PPPoE is up -​ Down Rate=46901000Kbps, Up Rate=18049000Kbps; SNR Margin Down=9.2dB, Up=6.0dB
18:36:59, 25 Aug.( 141.830000) PPPoE is up -​ Down Rate=48942000Kbps, Up Rate=19999000Kbps; SNR Margin Down=8.8dB, Up=6.5dB
01:02:04, 07 May.( 140.170000) PPPoE is up -​ Down Rate=48942000Kbps, Up Rate=20000000Kbps; SNR Margin Down=9.2dB, Up=6.1dB
07:47:32, 24 Aug.(572337.870000) PPPoE is up -​ Down Rate=48942000Kbps, Up Rate=19999000Kbps; SNR Margin Down=8.2dB, Up=7.6dB
04:48:27, 22 Aug.(388798.330000) PPPoE is up -​ Down Rate=48942000Kbps, Up Rate=20000000Kbps; SNR Margin Down=8.9dB, Up=6.4dB
16:50:26, 17 Aug.( 140.800000) PPPoE is up -​ Down Rate=46901000Kbps, Up Rate=20000000Kbps; SNR Margin Down=9.0dB, Up=6.2dB
 This is the extent of the log, if it would go back further it would of shown where the down rate was comparable to our original 46 Mbps.
Message 9 of 19
All the reset see the cause of your drop in connection. Line appears more stable now so hopefully if you maintain connection with no manual resets the DLM will start to reduce your noise margin and increase your connection speed. Unfortunately this can take a few weeks but is automatic
Sage
Sage
Message 10 of 19
You just have to look at the SNR down margin reported.
