Cobbmeister
Message 11 of 19
Re: BT infinity 1 Speeds on BT Infinity 2 - 74Mb actual dropped to around 34Mb.
I have given around 6 weeks ish for the noise margin to reduce. But it looks like there has been very little change. The HH5 has been left to its own devices. Still hitting around the 38Mb and sometimes lower. Checked on the infinity website, using both postcode an landline number it is still saying a minimum of 68Mb. Which is what we was getting around for the first 2 months or so.
08:08:50, 01 Nov.(323667.280000) PPPoE is up -​ Down Rate=38274000Kbps, Up Rate=19999000Kbps; SNR Margin Down=10.1dB, Up=15.4dB
03:08:37, 30 Oct.(132859.180000) PPPoE is up -​ Down Rate=38274000Kbps, Up Rate=19999000Kbps; SNR Margin Down=9.9dB, Up=15.1dB
15:16:26, 28 Oct.( 144.720000) PPPoE is up -​ Down Rate=38274000Kbps, Up Rate=19999000Kbps; SNR Margin Down=12.0dB, Up=7.1dB
06:31:42, 28 Oct.(16250.340000) PPPoE is up -​ Down Rate=38274000Kbps, Up Rate=19999000Kbps; SNR Margin Down=11.0dB, Up=6.7dB
03:02:59, 28 Oct.( 141.630000) PPPoE is up -​ Down Rate=42101000Kbps, Up Rate=19999000Kbps; SNR Margin Down=10.4dB, Up=7.0dB
22:21:48, 24 Oct.(935040.610000) PPPoE is up -​ Down Rate=42101000Kbps, Up Rate=19999000Kbps; SNR Margin Down=10.4dB, Up=6.7dB
20:04:00, 20 Oct.(581183.370000) PPPoE is up -​ Down Rate=42101000Kbps, Up Rate=20000000Kbps; SNR Margin Down=10.4dB, Up=6.4dB
Any help appretiated.
Message 12 of 19
You need to get an engineer to fix the line fault.
Message 13 of 19
have you checked quiet line test again?
with these drops in connection you are not going to make any progress and like licquorice said you need to get engineer visit
Cobbmeister
Message 14 of 19
BT booked for visit on 6th Nov , and now the line goes quiet without any crackle. Why does that happen, when you book a call out?
Just had a look on the HH5 and disconnections (PPOE Down) are appearing more regular at anywhere from 4 hrs to 40hrs. SNR down is now 12 db and up is 15 db.
Is it worth mentioning BB woes to engineer visiting? Or just let him concentrate on the line noise at hand?
Cobbmeister
Message 15 of 19
Just to add that the last 10 x PPOE Downs average at 29 hrs.
Message 16 of 19
if phone engineer then probably can't help with broadband but you can ask and see if he can help
Sage
Sage
Message 17 of 19
Up to you if you mention it to him but he will only be a line engineer and can't even get a profile reset for you.
Then again you may be lucky and get an engineer who has some broadband knowledge.
Cobbmeister
Message 18 of 19
Thanks. I had a line engineer turn up, with little knowledge of bt ininity/B Band. The line has been clear for a few days it seems that another engineer has been out to our cabinet a couple of days ago for someone else. Which may of also solved my noise issue. So the line engineer is giving it is now fixed / clear.
So with this in mind, what would be the next port of call ? I would inform BT of the broadband problem, but I can't see anywhere to ring / contact.D9 I need to request a profile reset or anything in perticular ?
Thanks.
Message 19 of 19
if noise problem now fixed you need a stable conenction for DLM to start improving your connection  what is your current connection time?  can you post stats from the HH5
