ethankeating00
Message 1 of 9
BT infinity 2 home hub 6 reset twice within 10 mins and speeds have dropped from 75 download to 38?
At around 5pm today I was playing a game only one in the house and my internet restarted on its own? The only times it restarts is every 5 days at 8:30PM So i knew it was unusually, so after the first restart i right away did a speed test and my speeds were fine. about 5 minutes after that it restarted again and so I did another speed test and my speeds dropped to 38 download and my maximum data rate dropped to around 48000 when it was 90000. I preformed at hard reset and speeds went up slightly I went from 38 down to 47  and upload went from 10 to 16  but im still not getting the full 80/20 I had! I had an issue like this last year in october which was fixed and not had an issue fixed! any help please?
8 REPLIES 8
McSure
Message 2 of 9
Re: BT infinity 2 home hub 6 reset twice within 10 mins and speeds have dropped from 75 download to
HaveHthe same issue except mines been off and on for the past 2weeks was getting 79/20 spoke to bt technical today who apparently fluhed and reset the network connection now im connected but at 62/20 not happy!!!!!!
ethankeating00
Message 3 of 9
Yeah last time in october an engineer came out and did DLM reset and fixed things! I'm gonna leave my internet to settle for a few days to see if that sorts things
ethankeating00
Message 4 of 9
Still no luck after a couple days speeds very slowly starting to decline! Last time I had this exact issue last year was fixed with a DLM reset. After some researching i heard it is no possible for it to remotely be done without calling out an engineer! Anyone able to help with that?
Moderator
Moderator
Message 5 of 9
Hi @ethankeating00
Thanks for your posts and welcome back!
Sorry you're having problems with your broadband speed again.  I recall it was myself that gave you a hand with this last year.  I realise it has been a few days since you posted.  How is your broadband speed performing now?
Post back and let me know.  If you are still having problems I can give you a hand from here.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
ethankeating00
Message 6 of 9
issue has been fixed! Only 1 thing I noticed is now my maximum data is at 76000 it used to be 90K-100K I know it won't matter but sometimes it dips below 70k lowering my speeds slightly
Moderator
Moderator
Message 7 of 9
Thanks for letting me know @ethankeating00
Great to see the issue has been fixed.  There could be a few reasons why the maximum data has decreased but as you said it doesn't matter as it's not affecting your actual connection speed.
Cheers,
Robbie
Kudos”
ethankeating00
Message 8 of 9
if the speeds start to dip because of it i'll let you know! thanks!
Moderator
Moderator
Message 9 of 9
You're welcome @ethankeating00  :smileyhappy:
Kudos”
