Message 1 of 27
BT infinity 2
Wonder if someone can help me out?  I am on infinity 2 and was superb when I first signed up to it, and had no real problems until lately.  When I check the router  I get a download sinc of only 25.51 Mbps.  Seems a little low as when I look at the bt account it says speed up to 67Mb.  I know I wont get that speed but 25.51 Mbps just seems a little low. I have listed some of the BT's smart hub specs below.
Connection status:
BT Broadband /
BT Infinity /
BT Infinity 3 and 4 :
BT Infinity
 Firmware version:
SG4B1000B540
 Firmware updated:
03-Jun-2018
 Serial number:
+084319+NQ62193797
 Downstream sync speed:
25.51 Mbps
 Upstream sync speed:
6.42 Mb
When I first had it it was about 45Mb but now at 25.51 just seems like a big drop.
Thanks.
26 REPLIES 26
Recognised Expert
Message 2 of 27
Re: BT infinity 2
Initially you want to ( if not already done) check your line for noise from the master socket test port, using the test port eliminates any internal wiring , extension sockets etc ( BT and Openreach are not responsible for those things )....from the test port , preferably with a corded landline phone , dial 17070 and take the quiet line test option , listen , the line should be clear , any 'noise' report to your line rental provider as a noisy line.
If the line is clear , and if not already done, connect your router to the test port and check for any improvement.
The router stats posted are not the full router stats, try looking and posting the more comprehensive router stats, and using your phone number , post the estimated available speeds for your line at this site
https://www.dslchecker.bt.com/
Sage
Message 3 of 27
Re: BT infinity 2
Could you post the connection stats from the hub.
HH6 Advanced settings/technical log.
HH5 Troubleshooting/helpdesk.
Message 4 of 27
Re: BT infinity 2
Product name:
BT Hub 6A
Serial number:
+084319+NQ62193797
Firmware version:
SG4B1000B540
Firmware updated:
03-Jun-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
2 Days, 23 Hours 52 Minutes 1 Seconds
Data rate:
6.42 Mbps / 25.51 Mbps
Maximum data rate:
6421 / 30380
Noise margin:
6.7 dB / 6.4 dB
Line attenuation:
25.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
9577 MB Uploaded / 39739 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
Menna
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
Menna-5
5 GHz wireless channel:
Smart (Channel 48)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 3
Firewall:
On
MAC address:
90:4D:4A:13:8B:73
Software variant:
Boot loader:
7.33.1
Message 5 of 27
Re: BT infinity 2
Thanks, will check the line tomorrow morning and do the dslchecker.
Sage
Message 6 of 27
Re: BT infinity 2
When you do the DSL checker, remove your number before posting but leave the exchange and cab number intact.
Message 7 of 27
Re: BT infinity 2
Did the quiet test and the line is clear, the phone socket is a openreach mk 3 with the router wire above and a phone socket underneath so can't see the test port socket.   Had to plug the HH5 back in as I thought the smart hub was working alright, but after a couple of days it decided to start playing up,   connection had dropped to 17 Mbps and getting slower, and is currently 27.5 Mbps.   Also did a fix a fault on the BT website this morning and it said there is a problem so had to speak to bt who did some extra tests and came back to say there is a fault maybe on the master socket so will have to send an engineer out.   They said it wasn't the equipment as I have tested it already.   The router is plugged straight into the master socket so  it can't be the wiring from the master socket to the router.
Thanks.
Message 8 of 27
Re: BT infinity 2
Also did a dslcheck if it helps.
Exchange PONTRHYDYGROES is served by Cabinet 1
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
46.9
32.4
8.2
6
27.4
Available
VDSL Range B (Impacted)
44.8
27.4
8.1
5.5
22.4
Available
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand
330
30
Available
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 17
10 to 19.5
Available
WBC ADSL 2+ Annex M
Up to 17
Up to 1.5
10 to 19.5
Available
ADSL Max
Up to 8
7 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Observed Speeds
VDSL
Max Observed Downstream Speed (Mbps)
26.1
Max Upstream Observed Speed (Mbps)
7.03
Observed Date
2019-03-20
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise environment
Status
Bridge Tap
N
VRI
N
NTEFaceplate
N
Last Test Date
11-03-2019
Message 9 of 27
Re: BT infinity 2
test socket is shown by black arrow  you need to remove the section shown by yellow arrow to see test socket
Message 10 of 27
Re: BT infinity 2
There is a test socket, but its situated behind the filtered faceplate. If you can test from that point, it would eliminate an issue with the NTE, as they can give problems.
The "real" test socket is the one to use.
I see @imjolly  has posted a similar picture.
