Message 1 of 10
BT infinity slow speeds at peak times
Hi
I've got slow speed at peak times, I get approx 5 mb  download upload approx 10.
Off peak I get approx 48 download  and 10 upload.
Please help
9 REPLIES 9
Moderator
Moderator
Message 2 of 10
Re: BT infinity slow speeds at peak times
Hi @Draj,
Welcome to the community forum. I'm sorry to hear that you are experiencing a slow down during peak times.
Please can you run the BT Speed test using the link http://speedtest.btwholesale.com/, the next time you notice the slow down? You'll need to run that test using a wired connection . Once the first test completes, please run the "Further Diagnostics" as this will test your speeds over the BT network and should help us to identify where the slow down is occurring.
Once you have run that test, please post back the results?
PaddyB
Message 3 of 10
Hi
I ran the test a few times, each time I ran further diagnostics i kept geting the following error
Are you able to see the results your end?
Sage
Message 4 of 10
Just keep trying during peak times.
Message 5 of 10
Hi
Message 6 of 10
Please do not run any further tests as it will overwrite that result on BT Wholesales' servers
Moderator
Moderator
Message 7 of 10
Thanks for posting the results @Draj. Which exchange are you connected to?
Cheers
David
Message 8 of 10
According to a search I did I should be connected to Thurnby, leicestershire
Moderator
Moderator
Message 9 of 10
Hi @Draj,
Thanks for confirming that. There are no problems at the Thurnby exchange but further back there are problems at Leicester Central which requires further infrastructure. There are plans in place for that to be completed on the 10/02/17.
Cheers
David
Message 10 of 10
Ok
Thank you for looking into this.
