Jamie8419
Message 1 of 21
BT infinity very slow download speed at night
Hi I've been having awful download speed since just before Christmas say 15th of December. I pay for the 72Mb down & 19Mb upload. I'm getting between 5Mb-19Mb download at the times of 4:00pm-3:00am. Upload speed goes down to 12Mb then bounces bk up to 19Mb like 5 mins later. Turned all wifi devices off then used Ethernet from my Hub to my laptop & same speeds happen. Done like 30 Bt wholesale speedtest then further diagnostics so they receive the speed test on the server. All of the tests are awful speeds of I test between those times of 4pm & 3am. Openreach came out said it sounds like REIN but BT then told me they checked that & for a hot VLAN and all is good on their side. I'm at a loss. Could anyone advise me with some help? PS Also I've had every possible electrical device turned off that I think would cause like interference but nothing goes on between those times that isn't on any other time in the day. Regards Jamie8419
20 REPLIES 20
Distinguished Guru
Distinguished Guru
Message 2 of 21
Re: BT infinity very slow download speed at night
Post a screenshot of a Further Diagnostics speed test and state your exchange and we'll get a mod to look into it for you.
Message 3 of 21
can you post diagnostic results with ethernet cable when speed appears ok probably off peak then when it is bad probably peak to illustrate your problem
Jamie8419
Message 4 of 21
Jamie8419
Message 5 of 21
Also I'm at the Alexandria OLO WSALE.
Moderator
Moderator
Message 6 of 21
Hi @Jamie8419 Welcome to the community and thanks for posting, I'm sorry to see you're having problems with your connection.
I can see there is a congestion issue reported with a SVLAN on the Alexandria exchange which is likely the reason why your connection is slow during peak times.  There's a fix date for new infrastructure to be added in March but we may be able to get your connection moved to an different SVLAN if you send in your details on the 'click here to contact the mods' link. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Jamie8419
Message 7 of 21
Thanks Neil I've got more from you than I did from BT customer care within a few hours than they told me within 1 month of complaints and equities from myself., They told me there was no problem with the VLAN. Also tried to scare me off asking for an engineer as the problem happens at night and he could only send a engineer out during day hours so I would have to pay a charge when they don't find a problem on the line. I will follow your link and see if there is a possibility of having my it moved. Kind regards Jamie.
Moderator
Moderator
Message 8 of 21
Hi @Jamie8419 I called earlier on your mobile and landline sorry I could not reach you.
I have checked and your SVLAN is not the one listed with the issue on the Exchange that Neil thought maybe affecting your connection. As @imjolly has requested above please can you complete a speed test when the connection is working OK off peak and afterwards perform another test to log the poor connection results.
The report on the status of the SVLAN's at your Exchange will be updated again on Wednesday and I will check to ensure if congestion is reported on your SVLAN again then but please complete the 2 speed tests requested above to help me progress the fault with your connection and I will update you again on Wednesday.
cheers
John
Community ModeratorJohnC
Kudos”Kudos”
Jamie8419
Message 9 of 21
Thanks John I will do. Sorry I'm unable to receive any calls and I finish work late in the evening so was unable to take any calls I had missed today. I will be free on Friday and I believe there is another engineer scheduled to come out on the 26th. Regards Jamie.
Distinguished Guru
Distinguished Guru
Message 10 of 21
If @JohnC2 confirms congestion being the issue then cancel the engineer.
Engineers cannot rectify congestion issues.
