Moderator
Moderator
Message 21 of 21
Re: BT infinity very slow download speed at night
Hi @Jamie8419
Thanks for posting back and I'm sorry you're having speed problems again.
Can you complete the speed tests again during peak/off peak times and post back so we can compare?
Link to speed tester
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
