Message 1 of 7
BT junction Box issues when raining?
hello
Just notice outside my property that the junction bt box has collapsed as the lid comes off and not nice inside so I was just wondering where I report this? Could this also explain the problem I get when my internet goes down in heavy rain?   IMG_0305.JPG
6 REPLIES 6
Distinguished Guru
Message 2 of 7
Re: BT juction Box issues when raining?
Do you have any noise on your telephone line if you plug a know working corded phone into the test point of your main telephone socket?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 7
no but i only notice the issues when heavy raining but still need to know were to report this as it has been like this for a  long time and it is a bit of a health and saftey issue as someone could fall down it as the lid doesn't stay on.
Message 4 of 7
Message 5 of 7
Hopefully will be out to repair it tonight or tomorrow thanks
Distinguished Guru
Message 6 of 7
When Openreach attend they will only make the area safe by erecting some guards around the damaged box. The engineer will then fill out some paperwork that will start the process off to replace the damaged joint box.
They would not be looking for any issues you have with your Broadband.
That would need to be reported to your comms provider, not direct to Openreach.
Message 7 of 7
Pah, **bleep** guarding it off and filling out paper work.
I’d just fill the **bleep**er in with that mud and those stone and reclassify it as a Buried Joint.
