Message 1 of 17
BT not providing broadband service I'm paying for
Ok so here's the rub. I have recently noticed that the speed of my broadband connection is much lower than the speeds I am supposed to be receiving. For reference this is the BT Fibre 1 with Halo 1 package that I am paying for
50Mb - 50Mb
Your download speed
Your Stay Fast Guarantee 25Mb   (note this has actually changed from 30 Mb down to 25Mb since I started having this problem see here: 20201102034427.jpg
Upload speed 10Mb - 10Mb
I have performed multiple speed tests over the past 2 weeks or so which all show consistent results of
19-20Mb download    1-1.25 Mb upload
This is actually an ongoing issue with BT. I have spoken to no less than 5 call center agents, 1 manager, had one engineer visit to the house and 1 line engineer visit which was promised but completely failed to ever happen.
When this fault was initially raised it appeared on my MY BT page as dropped broadband connection and has now been changed (as an entirely new fault) as "Landline -can't make or receive calls"
So ok... BT have absolutely no idea how to fix this issue and honestly have shown me over my time interacting with their support channels that they don't even know what the problem actually is. It's been dealt with so badly that I am still in disbelief. Anyway, they can't fix it so lets see if I can't get anywhere with some assistance from the community (that I should have never had to rely on in the first place). Here's the basics.
Quiet line test:
A-okay. confirmed by BT engineer during visit to property
Router Stats Technical Log:
Product name:
BT Hub 6A
Serial number:
+084319+NQ64358388
Firmware version:
SG4B1000E040
Firmware updated:
02-Nov-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
3 Days, 8 Hours 26 Minutes 52 Seconds
Data rate:
1.40 Mbps / 24.07 Mbps
Maximum data rate:
1403 / 24346
Noise margin:
6.6 dB / 3.1 dB
Line attenuation:
67.8 dB
Signal attenuation:
26.9 dB / 38.8 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
104 GB Uploaded / 58 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-PSTX
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-PSTX-5
5 GHz wireless channel:
Channel 48
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:4D:A0:B5
Software variant:
Boot loader:
7.33.1
Broadband Checker Details:
elephone Number {redacted} on Exchange KILMARNOCK is served by Cabinet 18
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
66.547.31610.240AvailableAvailable--
64.54015.69.132.4AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessWBC FTTP
Upto 1000Upto 220--Available1 Stage
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 11--8 to 13.5AvailableAvailable--
Up to 11Up to 18 to 13.5AvailableAvailable--
Up to 6--5 to 8AvailableAvailable--
2----AvailableAvailable--
2----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
23.83
1.23
2020-10-23
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
03-11-2020
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
The premise/line is associated with exchange which is NOT part of current fibre priority programme.
The premise/line is associated with exchange where WLR is not withdrawn.
The premise/line is associated with exchange where SOADSL service is restricted.
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential OH Feed with no anticipated issues.
FTTP is available and a new ONT may be ordered.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 31 Dec 2012. The Formal Retirement date for IPstream is from 30 Jun 2014.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Thank you for your interest
Things That May Be Of Interest:
BT website shows that my premises should be able to handle every package from Full Fibre Essential right through to Full Fibre 900
The engineer visited and confirmed using his equipment that the landline was iin perfect working order, there are no faults with the cabling in the premises and also performed a speedtest on his own equipment which showed results consistent with the ones I had done. The engineer checked for congestion and confirmed that the local usage should not impact the speeds I am receiving. He also stated that he was changing it from (or to) 5Ghz from (or to)  the 2.4Ghz although I'm not sure this really matters as from what I understand this is simply the wireless frequency and my hub is actually connected to my computer via an ethernet and doesn't use the wireless. I might be reading that wrong and that may not be what it is but for the sake of clarity just know the engineer did this when he was here. This visit was on Monday and concluded with the engineer saying that he would escalate the issue and arrange for an Openreach line engineer to come out before Wednesday to check the line between the premises and the cabinet (which I actually believe is sitting directly outside my bedroom window no less than 20ft from the premises. I may be wrong but I've certainly seen Openreach engineers in that box.)
If you require any further information I will be happy to provide it.
My Speculation:
There's a toggle or slider somewhere on the BT systems which has not been set to reflect the speeds I should be getting.  The reason that I say this is because everytime I run the BT speed test it returns the speed at 21Mb and 1Mb and then says these results are "good" or within the expected ranges... which they are not. They might be if my account was still set to be receiving what was promised for my previous package but they most certainly are not for the package that I am on right now.
I don't know if you guys will actually be able to help but honestly I'm much more curious as to whether or not you'll do any better than BT themselves. At this point it has become less about getting the problem fixed than it has about building up a documented history of how BT have failed to deal with this and just how hard they have failed. So yeah, to date BT has had 10 days to diagnose and fix the error consisting of conversations with 5 advisors each lasting somewhere in the region of 2 hours, 1 conversation with a manager which lasted almost 30 minutes and included a promise to credit my account with £20 compensation and a 1.5 hour engineer visit on my property. And so far I still have absolutely no idea what the issue is or whether it can actually be resolved.
Tags (3)
16 REPLIES 16
Message 2 of 17
Re: BT not providing broadband service I'm paying for
As FTTP is available ask to be upgraded. Ring the FTTP team. 0800 587 4787
Message 3 of 17
Your hub shows a conenction speed of 24mb with attainable of 24mb and with noise margin down at 3.1 suggests G.INP is active.  A download speed of 21mb is good and consistent with a connection speed of 24mb
i doubt you are going to get much faster on FTTC and I agree with @pippincp  phone FTTP and get upgraded to. FTTP and whichever package you prefer whether same as you have of even speed of 900mb
Anonymous
Not applicable
Message 4 of 17
Hello @bobleonheart,
I'm a Fibre 2 customer and I'm getting my promised speeds, once it dropped due to a cabinet been broken into by thief's but resolved now.
Kind regards,
DanTMan64
Message 5 of 17
It's good and consistent with a connection speed of 24Mb... but not with the package that BT actually sold me which said I'd be getting a minimum of 30Mb. They've been consistently month after month taking money from me for something that they can't and haven't been giving me. Surely BT must have been fully aware that those were the speeds that they could offer me so why would they sell me a package which guarantees more than they could provide me.?
And honestly Download speed is not my big issue. The reason I upgraded to this package was for the upload speed. I said this when I got the initial package too as I planned on doing some streaming. The fact of the matter is I'm getting 1/10th of what I was promised with the package I payed for and for some reason not one person has ever said... "oh you won't be able to get what we promised you."
I mean here I am 10 days into the process of trying to get the issue resolved, I've spoken to more BT advisors during that period than anyone else I've spoken to and not one person has said... "can't do it" Which seems to be what you guys are telling me. Is this not a problem? I've been paying for this package for in excess of 2 years. Are you telling me that it's never been possible at any point during that contract period for BT to supply me with what they promised me? Shouldn't at least one person from BT have told me this given that the information to do so is so readily available that I could get it myself just by visiting two sites?
It's also worth me pointing out that I have an appointment for the 24th to be upgraded to a Full fibre 100 package which I've been led to believe is fttp. But how should I know at this point seeing as I've just found out that nothing BT actually said can be trusted in any way shape or form. How am I to know that:
Full Fibre 100
150Mb - 150Mb
Your download speed
Your Stay Fast Guarantee 100Mb
Upload speed 30Mb - 30Mb
will actually be what I get? I know you guys are just members of the community but surely you must get why I'm so blown away by all this.
At the end of the day is there anything that I can do about the fact that BT lied to me about what they were going to provide me with and is there anything I can do about the fact that for the past 10 days they have very clearly been stringing me along with false promises that they are going to perform some kind of magical fix to give me what they promised me? I mean this is still an open fault at this point. BT is still keeping me under the impression that they are going to fix this and fix my speeds.
Message 6 of 17
The Full Fibre 100 product is FTTP as opposed to the Fibre 100 product which is G.Fast.
You shouldn't have any speed problems with Full Fibre 100.
Anonymous
Not applicable
Message 7 of 17
I do understand where you're coming from, has you already said you already spoke to BT. You may already know about if you cancel during a contract you'll face a 'Cancellation Fee' unless their's a problem with your service. How many devices are connected to whatever BT Hub you have?
Kind regards,
DanTMan64
Anonymous
Not applicable
Message 8 of 17
Hello @pippincp,
Man I'd love to have G.Fast but Openreach has no future plans for my local area / cabinet.
Kind regards,
DanTMan64
Message 9 of 17
All G.Fast plans are on hold while FTTP rollout is being concentrated on.
Message 10 of 17
"The Full Fibre 100 product is FTTP as opposed to the Fibre 100 product which is G.Fast.
You shouldn't have any speed problems with Full Fibre 100."
Thanks I am glad to hear that at least. Still very annoyed that I've been paying £44 a month for 24+ months for a package that was apparently not even possible for me to get. It honestly feels like BT have had me over a barrel for 2 years having there way with me and there's nothing I can do about it.
