helenmac1cat
Message 1 of 6
BT once again, causing bad ping.
It's as if after 6 O'Clock BT just gives up, my ping is always really bad and it makes online gaming impossible.
C:\Users\Adam>ping 146.66.158.1 -t
Pinging 146.66.158.1 with 32 bytes of data:
Reply from 146.66.158.1: bytes=32 time=44ms TTL=53
Reply from 146.66.158.1: bytes=32 time=43ms TTL=53
Reply from 146.66.158.1: bytes=32 time=47ms TTL=53
Reply from 146.66.158.1: bytes=32 time=42ms TTL=53
Reply from 146.66.158.1: bytes=32 time=50ms TTL=53
Reply from 146.66.158.1: bytes=32 time=41ms TTL=53
Reply from 146.66.158.1: bytes=32 time=48ms TTL=53
Reply from 146.66.158.1: bytes=32 time=38ms TTL=53
Reply from 146.66.158.1: bytes=32 time=39ms TTL=53
Reply from 146.66.158.1: bytes=32 time=34ms TTL=53
Reply from 146.66.158.1: bytes=32 time=36ms TTL=53
Reply from 146.66.158.1: bytes=32 time=37ms TTL=53
Ping statistics for 146.66.158.1:
    Packets: Sent = 15, Received = 15, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 34ms, Maximum = 50ms, Average = 41ms
 and a tracert
C:\Users\Adam>tracert 146.66.158.1
Tracing route to 146.66.158.1 over a maximum of 30 hops
  1     2 ms     2 ms     2 ms  BTHUB5 [192.168.1.254]
  2     9 ms     8 ms     7 ms  217.32.147.8
  3     8 ms    12 ms    11 ms  217.32.147.78
  4     9 ms     9 ms    10 ms  213.120.156.194
  5     9 ms     9 ms     9 ms  217.41.168.243
  6    10 ms     9 ms    10 ms  217.41.168.109
  7    21 ms    25 ms    12 ms  109.159.249.234
  8    10 ms     9 ms     9 ms  core4-te0-0-0-21.faraday.ukcore.bt.net [109.159.
249.175]
  9    11 ms     9 ms     9 ms  peer2-et-10-3-0.faraday.ukcore.bt.net [62.6.201.
171]
 10    11 ms    15 ms     9 ms  213.137.183.34
 11   111 ms    25 ms    25 ms  ldn-b3-link.telia.net [213.248.67.97]
 12   100 ms    15 ms    28 ms  ldn-bb2-link.telia.net [62.115.134.140]
 13    52 ms    20 ms    22 ms  prs-bb2-link.telia.net [80.91.247.240]
 14    23 ms    22 ms    22 ms  prs-b5-link.telia.net [213.155.131.143]
 15    48 ms    48 ms    47 ms  146.66.158.1
Trace complete.
 any fix, I usually get 20 to 25 ping not 40 to 70?
5 REPLIES 5
Sage
Sage
Message 2 of 6
Re: BT once again, causing bad ping.
I would suggest Telia is the problem, not your connection.
Your pings are fine until it hits them.
If you have a windows m/c can you run a pathping in the cmd window just to see better where the problem is?
helenmac1cat
Message 3 of 6
What is telia?
Message 4 of 6
A Swedish telecom company providing that part of the network that is causing the problem.
Message 5 of 6
that means the problem is outside the BT network
helenmac1cat
Message 6 of 6
How can I solve this problem then, because it's making online gaming extremely difficult!
