Brandscill
Message 11 of 34
Re: BT suffering DNS problems once again?
I've sent details both to twitter team and the mods, now the waiting game begins
freddie5
Message 12 of 34
Would this issue result in ie freezing up and error reports like "blahblahblah.com is not responding"??
Because i've been suffering this quite alot over the last few days??
Brandscill
Message 13 of 34
Yep, exactly that.
freddie5
Message 14 of 34
Thanks, wondered why i was getting those issues and errors.
Oh, i'm in Derby btw, or is this problem confined to a particular area??
bkaz
Message 15 of 34
Same issues here - some websites very slow in loading. Trace route shows node 217.41.216.29 having a major slow down. Not showing up on BTR outage boards so look forward to the mods response/ update on this.
bkaz
Message 16 of 34
Tx john46. It is on Infinity connected bb too.
Brandscill
Message 17 of 34
Seems to be everywhere freddie. Nightmare down here in Horsham. Getting increasingly worse.
Distinguished Guru
Message 18 of 34
Have you tried using your BT wifi hotspot?
If not, I'll try again 🙂
Brandscill
Message 19 of 34
I have, and the neighbours... seems he will be as irate as me haha.
bkaz
Message 20 of 34
@brandscill: did you hear back from either BT Care or from the moderators as the issue seems to be continuing with in my case, the same bt network node showing high latency in trace routings?
