BSM
Message 1 of 13
BT (wait for) Infinity
I used to be on Total Broadband Option 1, and while the service was acceptable it wasn't something to shout about. However I was downloading in excess of my allowance.
In May I was persuaded to move to 20Gb Infinity 1, with a HomeHub 5.0, and was told that it would be faster because of fibre.
It isn't. It's slower than my original plan. And it's only Fibre To Cabinet, so I don't even have fibre coming into the house.
I have problems logging into BT mail, which is what I have to do often because BT often won't/can't download mail to my PC mail client. I click on Login, or My Account, or Help, and it just sits there doing nothing. I wait for minutes for any of my three browsers to open or open pages.
If I want to download a software update or similar it is a lottery if the download completes without timing out.
I am running Windows 7 Pro 64 bit + SP1 on a 6 month-old quad core PC with legs.
I have installed a Network analyser which gives greatly different results to the BT Speed Checker, which has taken up to 10 minutes before I stop it or it says there's a problem. Useless.
Example log:
Received
Current transfer rate 9 bytes/s
Average Transfer Rate 43 bytes/s
Maximum Transfer Rate 572 bytes/s
Sent
Current transfer rate 12 bytes/s
Average Transfer Rate 17 bytes/s
Maximum Transfer Rate 346 bytes/s
Received 2.56 KB
Sent 1.03 KB
Total Data Transferred 3.59 KB
Since 01/11/2014 14:34:54
Elapsed time: 00-01-00 (1 minute)
I'm paying £15.99 per month + VAT for a land-line which I haven't used for calls for 18 months. I'm paying £18.55 per month + VAT for Broadband that has never reached the speeds (20Gbps?) that BT offered.
For the money I'm paying and for the service I'm not receiving I could get a fabulous deal from another supplier. So why should I continue with BT??
12 REPLIES 12
Distinguished Guru
Message 2 of 13
Re: BT (wait for) Infinity
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
If not, I'll try again 🙂
BSM
Message 3 of 13
Thanks for the response. Log is:
1. Product name:                             BT Home Hub
2. Serial number:                             +068543+NQ41129103
3. Firmware version:                         Software version 4.7.5.1.83.8.173.1.6 (Type A) Last                                                       updated 21/05/14
4. Board version:                             BT Hub 5A
5. VDSL uptime:                               0 days, 00:14:42
6. Data rate:                                    9999 / 39993
7. Maximum data rate:                      22671 / 62128
8. Noise margin:                              14.5 / 13.4
9. Line attenuation:                          0.0 / 16.6
10. Signal attenuation:                     0.0 / 16.5
11. Data sent/received:                     1.4 MB / 40.8 MB
12. Broadband username:                 bthomehub@btbroadband.com
13. BT Wi-fi:                                    Yes
14. 2.4 GHz Wireless network/SSID:  BTHub5-N56K
BSM
Message 4 of 13
I am also currently waiting for the BT mail server to respond to my client.
Distinguished Guru
Message 5 of 13
You are running at the max for Infinity 1 - 40/10.
Are your problems over a wireless connection or over a wired ethernet connection?
BSM
Message 6 of 13
I had just rebooted the HomeHub which is connected via Cat 5e to my PC. I only occasionally use wireless for my lap-top or tablet.
Whilst I am currently using the connection to do operate in my browser (Firefox) my mail is not getting through.
I use MailWasher Pro to view and filter my mail on the server, and when satisfied I download the good mail via Thunderbird. Neither MailWasher not Thunderbird are currently able to log on to the POP server.
Distinguished Guru
Message 7 of 13
Is your problem actually with BT Mail only?
BSM
Message 8 of 13
No, although that is the most frustrating, since accessing BT mail through the web is hit and miss as well.
I have problems with anything that requires a connection, obviously anything to with web access, page response etc. Downloading software updates can also be problematic.
Distinguished Guru
Message 9 of 13
I think BT Mail has it's own problems at the moment.
Can you do a trace route in a CMD window?
tracert bbc.co.uk
BSM
Message 10 of 13
TraceRoute as requested:
C:\Users\BSM>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.246.103]
over a maximum of 30 hops:
1     *       8 ms     7 ms BThomehub.home [192.168.1.254]
2     *       *       *     Request timed out.
3     *       *       18 ms 31.55.186.197
4   17 ms   17 ms   18 ms 31.55.186.220
5   17 ms   17 ms   17 ms 195.99.127.56
6    17 ms   18 ms   18 ms peer2-xe8-0-1.telehouse.ukcore.bt.net [109.159.2
54.179]
7   19 ms   18 ms   18 ms 194.74.65.42
8     *       *       *     Request timed out.
9   19 ms   20 ms   20 ms ae0.er02.cwwtf.bbc.co.uk [132.185.254.90]
10   20 ms   19 ms   19 ms 132.185.255.165
11   21 ms   21 ms   21 ms fmt-vip132.cwwtf.bbc.co.uk [212.58.246.103]
Trace complete.
