garybs29
Message 11 of 20
Re: BT want to charge me extra to get minimum guaranteed speed. Unfair?
Accordong to the below link, theres a master socket change mentioned as well
http://bt.custhelp.com/app/answers/detail/a_id/60626/~/how-is-bts-ultrafast-fibre-broadband-installe...
bertiepma
Message 12 of 20
Thanks. But doubt it would be necessary in order to achieve the speed of 71-80 Mbps I paid for if they switched my service to GFast at the cabinet. They already upgraded my master socket 2 yrs ago, and the router is plugged in to it directly. I imagine my existing smart hub would work fine? As I said, I'm not looking for a new service, new equipment or minimum of 100 Mbps. It would just be nice if they found a way to make good on the originally advertised 71-80 Mbps now that it's possible. But I can see you disagree, and that's fine.
Tags (1)
Sage
Message 13 of 20
Your current router would not work on a G.Fast connection.
bertiepma
Message 14 of 20
Thank you for the clarification. Not as simple as I thought then. I will probably leave things as they are for a while then, because I hate to keep chucking away modems and stuff unless I really have to. It's a shame, but it's not very environmentally friendly to keep consuming electronics and plastic.
Sage
Message 15 of 20
Your local recycling place will take then.
Moderator
Moderator
Message 16 of 20
Hi @bertiepma
Welcome back to the Community and thanks for posting.
Sorry to hear that you are unhappy with the broadband speeds you are getting.
You mentioned that when you took out the service we told you:
"We estimate your download speed will be between 71Mbps and 80Mbps, and your upload speed will be between 19Mbps and 20Mbps. The minimum guaranteed speed you can expect from your broadband will be 64Mbps."
As long as you are getting speeds of 64Mbps to your BT Hub then you are getting the speeds you are paying for. You will never be able to get speeds over 80mbps on an FTTC connection as the max speed available on this service is 80mbps.
If you are getting speeds that are less than 64Mbps then we would do everything we can to improve the speed.
If you run a wired Speed Test what speeds are you getting at the moment?
Please let me know how you get on with the speed test.
Matt
bertiepma
Message 17 of 20
Thanks Matt. But I have done all that already, ad nauseam. The problem is that I am getting less than 64. Apparently the 'new' minimum for my address is 57, which I am getting (normally hits around 60).
Moderator
Moderator
Message 18 of 20
If we sold you a minimum of 64 this won't change however new customers in your area may be sold a minimum of 57Mbps.
If you are getting less than 64Mbps then we will need to take a look into this to make sure that we have done everything we can to increase the speed.
Can you post a screenshot of your hub stats please?
Matt
bertiepma
Message 19 of 20
I renewed my contract a few months  back over the phone. I suspect the new minimum of 57 was in place then, but I was not informed that it had decreased from the previous 64 minimum. I only found out about the 57 minimum speed when I phoned BT yesterday to query how it was now possible to achieve a minimum of 100Mb.  Like I said, I have been through all of this already with an engineer visit to the house also where he tested directly in the socket,  and concluded that I was getting the best speed achievable with the current setup.  I'm afraid I don't have the time or patience to go through it all again! Thank you.
Moderator
Moderator
Message 20 of 20
No problem but if you change your mind please let me know and post the hub stats. I personally don't think everything that can be done has been done in this case by the sounds of it.
Matt
