Message 1 of 2
BTt Hub dropping connection
Hi guys my hub has started dropping connection during the middle of the night. Its now affecting my speed.  I have checked the line and there is no issues.  Here are the error messages and the stats
01:03:24, 13 May.(441303.720000) PPP LCP Send Configuration ACK
01:03:24, 13 May.(441303.720000) PPP LCP Receive Configuration Request
01:03:24, 13 May.(441303.720000) PPP LCP Send Configuration Request
01:02:39, 13 May.(441259.050000) CWMP: session closed due to error: Could not resolve host
01:02:35, 13 May.(441254.820000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
01:02:35, 13 May.(441254.820000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
01:02:28, 13 May.(441247.860000) PTM over DSL is up
01:02:02, 13 May.(441221.940000) CWMP: session closed due to error: Could not resolve host
01:02:02, 13 May.(441221.690000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
01:02:02, 13 May.(441221.680000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
01:02:01, 13 May.(441221.010000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
01:01:57, 13 May.(441216.800000) PTM over DSL is down after 214 minutes uptime
01:01:57, 13 May.(441216.790000) PPPoE is down after 96 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
01:01:51, 13 May.(441211.100000) PPP LCP Send Termination Request [User request]
00:50:19, 13 May.BLOCKED 3 more packets (because of ICMP replay)
00:50:19, 13 May.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 81.152.116.225-​>104.120.213.16 on ppp3)
00:40:17, 13 May.BLOCKED 3 more packets (because of ICMP replay)
00:40:17, 13 May.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 81.152.116.225-​>88.221.18.246 on ppp3)
00:37:07, 13 May.OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.66]:59079-​>[17.167.192.231]:443 on ppp3)
00:34:42, 13 May.BLOCKED 2 more packets (because of ICMP replay)
00:34:42, 13 May.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 81.152.116.225-​>81.130.97.17 on ppp3)
1 REPLY 1
Message 2 of 2
Re: BTt Hub dropping connection
1. Product name:BT Home Hub
2. Serial number:+068543+NQ55034856
3. Firmware version:Software version 4.7.5.1.83.8.264 (Type A) Last updated 31/07/19
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 01:10:55
6. Data rate:1080 / 6033
7. Maximum data rate:1081 / 6534
8. Noise margin:6.3 / 5.3
9. Line attenuation:16.4 / 39.2
10. Signal attenuation:16.4 / 31.8
11. Data sent/received:53.0 MB / 363.8 MB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-8FN3
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:11
18. 5 GHz Wireless network/SSID:BTHub5-8FN35ghz
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:84:a4:23:12:64:50
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
