Message 1 of 5
Bad Ping Spikes
So my internet speed on my Playstation is alright, I get about 40mbps download and 8mbps upload, however despite this when playing games after certain times I still get really bad ping spikes. My ping can be at an average of around 15-20ms, but then erratically spikes up to 200 every 10 or so seconds. This only happens sometimes when nobody else is using the internet (and only late at night too, around 9pm onwards),  This basically means I can't play games after 9pm, so what can I do about it? My download speed is still fine and is pretty much unchanged, so what's the actual cause of these ping spikes?
I use a power line adapter, and my suspicion is that there is interference after a certain time however doing various test I believe this may not be the case, given that im not much of an internet guru, I was hoping for some expert community help to figuring out my problem, here is the tracert so that someone can help me figure out if the problem is on my end or the isp.
Tracing route to www.google.com [172.217.169.4]
over a maximum of 30 hops:
1 4 ms 11 ms 4 ms 192.168.1.254
2 * * * Request timed out.
3 * * * Request timed out.
4 47 ms 49 ms 35 ms 31.55.185.184
5 10 ms 12 ms 14 ms core2-hu0-6-0-8.colindale.ukcore.bt.net [213.121.192.28]
6 69 ms 81 ms 66 ms peer2-et-3-0-4.slough.ukcore.bt.net [109.159.252.122]
7 212 ms 60 ms 137 ms 195.99.126.75
8 * * * Request timed out.
9 14 ms 13 ms 14 ms 172.253.68.218
10 19 ms 26 ms 26 ms 74.125.242.114
11 21 ms 31 ms 25 ms 209.85.241.211
12 12 ms 14 ms 11 ms 216.239.58.128
13 15 ms 16 ms 17 ms 108.170.246.161
14 17 ms 15 ms 13 ms 209.85.241.95
15 74 ms 21 ms 16 ms lhr25s26-in-f4.1e100.net [172.217.169.4]
Tracing route to www.google.com [216.58.198.164]
1 32 ms 4 ms 4 ms 192.168.1.254
3 * * 14 ms 31.55.185.177
4 15 ms 15 ms 22 ms 31.55.185.176
5 15 ms 12 ms 15 ms core2-hu0-16-0-9.colindale.ukcore.bt.net [213.121.192.46]
6 17 ms 11 ms 10 ms 109.159.252.74
7 120 ms 40 ms 34 ms peer5-te0-0-0-32.telehouse.ukcore.bt.net [195.99.126.77]
8 26 ms 34 ms 15 ms 108.170.246.161
9 11 ms 14 ms 10 ms 108.170.232.99
10 11 ms 21 ms 11 ms lhr25s10-in-f4.1e100.net [216.58.198.164]
4 REPLIES 4
Message 2 of 5
Re: Bad Ping Spikes
sorry also this tracert and a ping is wired strait to the router
1 1 ms 1 ms 1 ms BTHUB5 [192.168.1.254]
3 * * 6 ms 31.55.185.177
4 7 ms 7 ms 7 ms 31.55.185.176
5 93 ms 81 ms 36 ms core2-hu0-16-0-9.colindale.ukcore.bt.net [213.121.192.46]
6 8 ms 7 ms 7 ms 109.159.252.74
7 8 ms 7 ms 8 ms peer5-te0-0-0-32.telehouse.ukcore.bt.net [195.99.126.77]
8 11 ms 10 ms 10 ms 108.170.246.161
9 9 ms 8 ms 8 ms 108.170.232.99
10 8 ms 8 ms 8 ms lhr25s10-in-f164.1e100.net [216.58.198.164]
Pinging www.google.com [216.58.211.164] with 32 bytes of data:
Reply from 216.58.211.164: bytes=32 time=214ms TTL=54
Reply from 216.58.211.164: bytes=32 time=8ms TTL=54
Reply from 216.58.211.164: bytes=32 time=9ms TTL=54
Reply from 216.58.211.164: bytes=32 time=145ms TTL=54
Reply from 216.58.211.164: bytes=32 time=100ms TTL=54
Reply from 216.58.211.164: bytes=32 time=7ms TTL=54
Reply from 216.58.211.164: bytes=32 time=177ms TTL=54
Reply from 216.58.211.164: bytes=32 time=105ms TTL=54
Reply from 216.58.211.164: bytes=32 time=285ms TTL=54
Reply from 216.58.211.164: bytes=32 time=67ms TTL=54
Reply from 216.58.211.164: bytes=32 time=15ms TTL=54
Reply from 216.58.211.164: bytes=32 time=11ms TTL=54
Reply from 216.58.211.164: bytes=32 time=28ms TTL=54
Reply from 216.58.211.164: bytes=32 time=10ms TTL=54
Reply from 216.58.211.164: bytes=32 time=66ms TTL=54
Reply from 216.58.211.164: bytes=32 time=16ms TTL=54
Reply from 216.58.211.164: bytes=32 time=73ms TTL=54
Reply from 216.58.211.164: bytes=32 time=222ms TTL=54
Reply from 216.58.211.164: bytes=32 time=191ms TTL=54
Reply from 216.58.211.164: bytes=32 time=12ms TTL=54
Reply from 216.58.211.164: bytes=32 time=280ms TTL=54
Message 3 of 5
Please Help Me Figure Out My Problem
Bad Ping Spikes
Message 4 of 5
Re: Please Help Me Figure Out My Problem
Have you tried missing out powerline adapter and try connecting direct with ethernet and see if that helps
Message 5 of 5
sorry that ping test and tracert were directly to the router without the powerline adapter
