Message 11 of 52
Re: Banded Profile and Possible Congestion.
Hi,
I still get the same line noise on the quiet line test, a faint phone like hum.
Product name:
BT Hub 6A
Serial number:
+084316+NQ71726102
Firmware version:
SG4B1000B540
Firmware updated:
28-Jan-2019
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 1 Hours 51 Minutes 56 Seconds
Data rate:
6.73 Mbps / 30.00 Mbps
Maximum data rate:
6732 / 34622
Noise margin:
6.1 dB / 8.3 dB
Line attenuation:
24.5 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
52 MB Uploaded / 1107 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-7R23
2.4 GHz wireless channel:
Channel 11
5 GHz wireless network name:
BTHub6-7R23
5 GHz wireless channel:
Channel 48
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:43:DF:49
Software variant:
Boot loader:
7.33.1
Techwizz
Message 12 of 52
A dull hum is normal if using a cordless phone. Can you try using a corded phone and see if there's any noise then?
Message 13 of 52
All tests have been performed with a corded phone, I've just tested again at the test socket with 2 different corded phones and there's still a hum, confirmed by another party.
Distinguished Guru
Distinguished Guru
Message 14 of 52
Then you have a line fault not a broadband one. report it on 151.
Techwizz
Message 15 of 52
Ok, then it's likely that you have an earth leakage fault, so as @pippincp said, you need to report a telephony fault to 151.
Message 16 of 52
Ok, but that's what I already did, call 151 and report a landline fault and the engineer who came out this morning couldn't find anything wrong.
I could ring again, but won't they just say the same thing again?
Moderator
Moderator
Message 17 of 52
@0123456789 I've sent you a Private Message with details on how you can get in contact with the mod team if you'd like us toi take a look at this.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 18 of 52
Hi @0123456789,
I've picked this up for you. I've sent a request to our suppliers to see if they can improve your connection speed. They may not be able to do it until Monday. I'll check up on it for you then.
DanielS
Community ModeratorDannyS
Kudos”Kudos”
Moderator
Moderator
Message 19 of 52
Hi @0123456789,
I've been checking to see if there has been any change yet but there isn't. I've sent another request to my suppliers to see if they can improve it over the next couple of days.
DanielS
Kudos”Kudos”
Message 20 of 52
Hi there @DanielS
thanks for all the assistance, my internet mysteriously reconnected at 4pm yesterday afternoon. After which it synced at 29.37 Mbps instead of the usual 30.0.
Strangely, the max sync is the same at roughly 35, but the SNR for the downstream has dropped from 8+ to 6, also my pings have increased by about 8ms across the board, so I'm guessing interleaving has been applied?
Interestingly if I check the WAN log it says it connected at 33539Kbps with 0 db SNR which is what it was saying every time it connected before.
When you say a speed increase through one of your supplies what exactly does that involve, is it just a DLM reset?
An extra piece of possibly relevant information is that this property has two extra phone lines that haven't been used in years, and from reading other threads I've seen this as being mentioned as a possible source of interference?
Thanks again.
