Moderator
Moderator
Message 21 of 52
Re: Banded Profile and Possible Congestion.
Hi @0123456789  Thanks for the update and @DanielS  will be back in the office tomorrow and update you then.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Techwizz
Message 22 of 52
@0123456789, a DLM reset has been performed on your line, hence why your latency has increased. This is because G.INP has been replaced by interleaving. Your speed will increase over the coming days once G.INP re-activates. 🙂
Moderator
Moderator
Message 23 of 52
Hi @0123456789,
As @Techwizz has said, you should notice a difference over the next few days. I'm hoping that it will be a positive change. If it isn't, I'll go over everything to work out the cause of the speed. At this moment we know you aren't banded any more and there's no reported congestion.
DanielS
Community ModeratorDannyS
Kudos”Kudos”
0123456789
Message 24 of 52
@DanielS @Techwizz
Ok great, I thought it was something along those lines, I'll see where the line settles at over the next week or so and report back. Thanks for everyone's help, I managed to trip a fuse last night resulting in a full reboot so I'm off to a great start! Smiley Frustrated
Techwizz
Message 25 of 52
One resync shouldn't cause an issue. 🙂
Moderator
Moderator
Message 26 of 52
There doesn't appear to be any change to the profile you're on so the trip doesn't look to have caused an issue Smiley Happy
Kudos”Kudos”
Moderator
Moderator
Message 27 of 52
Hi @0123456789,
I hope you have been keeping well. I'm going to be out of the office over the next couple of days but I will be here over the weekend. When ever you get a chance, can you let me know how it has been performing come Saturday?
DanielS
Kudos”Kudos”
Message 28 of 52
Hi @DanielS
After my connection was reset, it was resyncing every day or so at higher speeds until it hit 36/7 Mbps with a max achievable of 39 at target of 4DB Snr. Then the trend reversed with resyncs lowering the speed down to the current stats shown below, this is the first sync at which the max and actual sync have coincided. So at this point I'm not sure if it'll drop further back to a banded profile or not.
Moderator
Moderator
Message 29 of 52
Hi @0123456789
@DanielS is out of the office for the evening but he is back in again tomorrow morning.  I'll let him know that you've posted and he'll pick this up then Smiley Happy
Cheers,
Robbie
Community ModeratorRobbieMac
Kudos”Kudos”
Message 30 of 52
Attainable and actual speeds about same with noise margin normal and coming up for 2 days stable. No sign of any banded profile
