Moderator
Moderator
Message 31 of 52
Re: Banded Profile and Possible Congestion.
Hi @0123456789,
You profile is showing as being on our 55/10 profile which means that the speeds aren't being banded/restricted. Your download speed range is showing as being between 23Mb-36Mb so the current speeds do seem to be about the best that you can get.
The BT Wholesale availability checker seems to be removed at the moment but this is the information I have:
                            Downstream  Mbps Upstream Mbps
                         High                  Low     High            Low
Clean                40                      25      7.8               5.4
Impacted        38                      21      7.7               5
Since the 1st of April until the 12th of April I can see 6 changes made by DLM, mainly changes to the noise margin to help keep the connection stable.
I also ran a line test today and it’s coming back as being stable with no adverse line test history.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
Message 32 of 52
Hello again @DanielS
Just had my 4th resync since we last spoke, the speed dropped down to 32, 31, 31 respectively and now this:
These are DSL resysncs, the router uptime is 10 days+
So I think I'm back to banding. Smiley Sad
Message 33 of 52
you line stats don't show as if banded - don't know why you keep posting about banding.  if your line is dropping connection as often as you say then there is a line problem and needs fixed  your connection speed currently is just below attainable and within your expected speed range
Message 34 of 52
Hi there, @DanielS
Sorry to be a pain, but I've had a couple more resyncs since my last post and I'm now down to this:
Which is out of my expected speed range. I've tried a standard line engineer who said the line wasn't noisy enough, I've tried a DLM reset which didn't help as obviosuly there is still a line fault somewhere. What's the next step a Boost Engineer?
For reference, my next door neighbour who is close to and equidistant from the distribution point as me gets a sync of 38 with low SNR targets. They have practically the same expected speeds as me too.
Message 35 of 52
are you using the test socket with a filter to see if that improves/stabilises your conenction?  if in test socket can you hear any noise whatsoever on the quiet line test
your neighbour's conenction is a guide but your pair of wires are different to his and may produce different results
0123456789
Message 36 of 52
Hi there,
Ok, turned the broadband off for over 30 minutes to not upset the DLM and reconnected to the test socket with a filter:
It's connected at exactly the same speed, and yes the faint noise on the line was there when tested on the test socket, with or without the filter.
I'll leave it there for the time being to see what happens.
Message 37 of 52
leaving in test socket might help stability but not sure it will help if you can still hear noise on quiet line test - it should be silent.  I think you are going to need an engineer visit before you will get back to previous speed
Moderator
Moderator
Message 38 of 52
Hi @0123456789,
I will be in the office over the weekend and I can look into this for you then if you still have issues.
I'll check for a reply from you on Saturday when I'm here Smiley Happy
Any issues before then please let us know so one of my buddies here can help.
DanielS
Kudos”Kudos”
0123456789
Message 39 of 52
Hi @DanielS
My connection has remained the same since my last post.
Message 40 of 52
so your line is now stable since moving to test socket?
