Black_Infinity
Message 1 of 36
Banded or Not ??
Just a quick question having read a recent thread here.
How do you determine whether a line has been banded or not ??
35 REPLIES 35
Message 2 of 36
Re: Banded or Not ??
Did you read this, as it explains it better than anywhere else?
https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
If your downstream noise margin is higher than 6dB, then you are in a banded profile.
Message 3 of 36
A higher than 6dB margin does NOT always indicate banded profiles.
Black_Infinity
Message 4 of 36
Thanks for the info.
At present my noise margins are 6/6.4 and and have been that way for quite some time now.
Message 5 of 36
Then its unlikely to improve any further.
What is the problem?
Black_Infinity
Message 6 of 36
Not so much a problem but with a max data rate of 30+ I only ever sync at 27.4 giving me an actual download speed of around 24.
The sync rate of 27.4 never changes even by a small amount but the upload rate does seem to vary a little.
Message 7 of 36
27.4meg is a banded profile.
Moderator
Moderator
Message 8 of 36
Hi @Black_Infinity and thanks for posting.
@Webby might be correct here so I'll be happy to take a look at this for you. Can you run the speed test including the further diagnostics and post the results?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Black_Infinity
Message 9 of 36
 Thanks David, here is the info you requested
Message 10 of 36
What does http://dslchecker.bt.com show for your line?
I'll be honest, unless there's a fault, there's nothing wrong with your connection. Being a few meg shy of the max attainable is totally normal. Even if you were syncing at 30meg, you'd see no improvement in your day to say usage. All you'd see is a higher number on a speed test.
