Sage
Message 21 of 94
Re: Banding 'stuck' or just impatient me?
As you are on a Huawei cab then G.INP is enabled on all lines that does not mean it is active on all lines. It will only be active on lines DLM deems beneficial. It's a much more complicated algorithm but I'm sure you get the drift.
As regards SNR I think you really need to read up on what it actually means, Signal to Noise Ratio.
Your try reduced it to 0 Db which is 1:1. Impossible outside of lab conditions and doubtful then.
As I said previous, modem SNR control worked to an extent on ADSL lines but I've yet to see the results on VDSL.
Message 22 of 94
I think I get SNR at this level... desired signal level vs background signal (noise) level...
I guess we wait until the DLM becomes happy with the router and the line... or I start whining about the banding...
Once the banding is off I can try shifting the SNR from this end and see if the link speed changes.
A line profile soft reset would be nice at this point tho...
Sage
Message 23 of 94
Too soon, don't blame your ISP.
Message 24 of 94
I'm not blaming anybody, certainly not blaming BT for protecting their network. DLM is just doing it's job.
I'm just hunting knowledge and expediency. 😉
Message 25 of 94
Is there any method for an end user to determine the ILQ status of a line?
Sage
Message 26 of 94
No.
This may be of help.
https://kitz.co.uk/adsl/DLM.htm
Message 27 of 94
Can / will you?
Sage
Message 28 of 94
@Slvrbck wrote:
Can / will you?
Message 29 of 94
Just wondered if you had access to BT systems...
Sage
Message 30 of 94
No. This is a consumer supported forum. The only BT employees are the mods.
