Message 1 of 12
Better speeds/fibre
Hello I’m moving to a flat in April and I was looking into the internet around the are I rang up bt and various other providers they’ve came back and said the internet speed will between 15-18 download and ca guarantee 13 download as they explained fibre isn’t quite available due to nearest cabinet only being cooper wiring how do I know or what can I do to try get fibre or faster internet
11 REPLIES 11
Message 2 of 12
Re: Better speeds/fibre
Try using your address and post results.
Message 3 of 12
Hello won’t let me post a photo as it says the picture is too large
Message 4 of 12
What results would you like ?
Message 5 of 12
You need to use the camera icon.
Message 6 of 12
Message 7 of 12
Message 8 of 12
As you can see you cannot get FTTC (VDSL) as the cabinet is full and there is a theoretical waiting list. The only broadband on offer is adsl2 hence the lower speeds. You just need to keep checking until you see available and the place order or ask for upgrade to fibre
Message 9 of 12
Will the speeds there offering be good enough for gaming,watching movies ect
Message 10 of 12
@Todd99
Yes it should be fine for watching SD movies and gaming, but gaming would work better when movies are not being streamed at the same time. Latency is usually lower on ADSL owing to the better connectivity in the exchange.
Some VDSL customers get less speed than ADSL, if they are a long distance from the cabinet. You must be fairly close to the exchange.
