Yelekreb
Message 11 of 19
Re: Blue light on the hub but no internet access
How do I know which is my local exchange? I’m in Cardiff and BT say there are non issues on the line. The router won’t even accept a password. I have a stack of BT routers that they keep on sending me and the same thing. Blue light no internet. The openreach engineer couldn’t connect his laptop with a direct cable connection. I was due an update yesterday but haven’t heard a thing.
imjolly
Message 12 of 19
enter your phone number  https://www.btwholesale.com/includes/adsl/main.html
licquorice
Message 13 of 19
Then the Openreach engineer should have escalated the problem, has the fault been closed?
Yelekreb
Message 14 of 19
Great thanks. Llanishen - cabinet 14
Yelekreb
Message 15 of 19
No idea. I’ve had no update. But historically the fault keeps on being closed and reopened as when I call the helpline again I’m told the fault is closed! We’ve had a line dropping problem for many months but zero connection now for 10 days. I can’t even log into the router with a direct connection
JohnC2
Moderator
Moderator
Message 16 of 19
Hi @Yelekreb Sorry you have lost your broadband connection.
Did you receive an update yet? Is the fault report still open?
Post back and let me know.
cheers
John
imjolly
Message 17 of 19
@Yelekreb
you do not need an internet connection to access the hub using an ethernet cable - only need power cable connected
Yelekreb
Message 18 of 19
Hi there, No update recieved and I don't know if the fault is still open yet. However i know a 'lift & shift' was done on saturday, but we still had no service. I spent a couple of hours doing factory resets on the router and suddenely we have service! I don't know if this is the 'lift & shift', the resets, a combination or something else. The speed is very variable, which I guess is normal as the service beds in. However, hopefully this has fixed the drop out problem as well (the line would drop several times a day), but only time will tell. Will update once I hear back from BT.
JohnC2
Moderator
Moderator
Message 19 of 19
Hi @Yelekreb Thanks for the update and as you say hopefully the issue is resolved now. Come back and let us know if it isn't.
Cheers
John
