jonmanley
Message 11 of 49
Re: Broadband Boost
So it would seem.
Before the free "Broadband Boost" I had around 50mb.
After the boost I had around 60mb.
On 5 Jan I recontracted.
Now I am back to around 50mb.
imjolly
Message 12 of 49
Re: Broadband Boost
Just need your router stats now
jonmanley
Message 13 of 49
Re: Broadband Boost
Happy to provide them, but need a pointer as to where the info you require is found.
imjolly
Message 14 of 49
Re: Broadband Boost
This may help https://community.bt.com/t5/Announcements-Guides-Community/Broadband-Top-Tips-to-get-help-on-the-for...
jonmanley
Message 15 of 49
Re: Broadband Boost
Thanks, but when I get to the Event Log there is a whole host of entries, but I cannot find the DSL info.
I have a Homehub 4
Any help much appreciated
Keith_Beddoe
Message 16 of 49
Re: Broadband Boost
You must have a white Openreach modem as well, if you are using a home hub 4?
Like this Home hub 4 with modem
jonmanley
Message 17 of 49
Re: Broadband Boost
From a brief search - it appears that info is available from the router not the hub, and I have no way to access the router software.
Keith_Beddoe
Message 18 of 49
Re: Broadband Boost
Its held in the Openreach modem as shown on my picture, and is not acccesible unless you have an unlocked modem.
All new installations use either a home hub 5, home hub 6, or people use their own VDSL modem/router (from £30)
All these provide connection information, so at the moment there is no way of telling whether you have a boosted speed.
imjolly
Message 19 of 49
Re: Broadband Boost
run btspeedtester and when first test completes then run diagnostic test and post results http://speedtest.btwholesale.com/
jonmanley
Message 20 of 49
Re: Broadband Boost
Done, but only get speed results, no router stats.
Just get Best Effort Test.
