jonmanley
Message 21 of 49
Re: Broadband Boost
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 49.98 Mbps
0 Mbps51.49 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 49.98 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-51.49 Mbps .
 Additional Information:
 IP Profile for your line is - 51.49 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 8.55 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 8.55Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
imjolly
Message 22 of 49
Re: Broadband Boost
from the btspeedtester results your up profile is 20mb showing you are on infinity2
jonmanley
Message 23 of 49
Re: Broadband Boost
Thanks.
Any ideas why I might have lost the "Boost" of the xtra 10mb they gave me in November.
jonmanley
Message 24 of 49
Re: Broadband Boost
Just onto Sales and it looks like the boost has been removed because I recontracted - despite being assured that if I did so nothing would change!
Spoke too soon - they say I should be getting 60+
Back to the faults team I guess!
jonmanley
Message 25 of 49
Re: Broadband Boost
Long conversation and various tests reveal no faults.
I am listed as being on up to 76mb.
It seems the other 10mb just evaporated, and may or may not come back some day!Smiley Surprised
PaddyB
Moderator
Moderator
Message 26 of 49
Re: Broadband Boost
Hi @jonmanley,
I'll be able to take a look at your connection and run a few checks on your line. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
jonmanley
Message 27 of 49
Re: Broadband Boost
Thanks Paddy,
Let me know what information you require - just found out there is a form, so will complete it.
BR
Jon
jonmanley
Message 28 of 49
Re: Broadband Boost
PaddyB has now tested my line and it seems there IS a network fault which he has referred to Wholesale, so fingers crossed!
Thanks Paddy.
pippincp
Sage
Message 29 of 49
Re: Broadband Boost
@PaddyB will get you sorted, just stick with him and don't ring support.
jonmanley
Message 30 of 49
Re: Broadband Boost
Will do!
