Message 1 of 5
Broadband Connection dropping continually
I decided to change my broadband to get better speed & service. This seems to have been a mistake. Firstly I work some of the week from home thus needing connection to my office 24/7.
I got setup last week & had a really good speed & connection.
On Friday my connection dropped off during a playtest (I work in the games industry) & since then it will periodically connect then drop out after a few minutes.
After a few calls to the Indian call centre & the try this, turn it off & on routine, the guy on the line sees that there is a issue & mentions a crossed line? My phone has a dial tone even when the connection cannot be made so I'm assuming it's an issue at the exchange?
Anyhow the problem is escalated & a guy calls me back today and tells me the connection has been consistent for 24 hours. Sorry pal but it hasn't.
I explain this be am told that the hub has a connection (which it did at that moment) so I have to monitor it and if it drops out text him on a number he has just sent me.
Surprise surprise it drops again 2 minutes later. I text.... wait 15 minutes, no call. So I go onto my BT & check the fault only to find someone else's email address & phone number in the contact section????
How is this possible? Is this not a data protection issue? Does someone else have my contact details on their fault ticket? I hope not & I'm not happy about it.
Soon after I get a call to book an engineer to come to my property & have the warning that if there is a problem within my property boundary I have you pay £129.99
I'm barely a week in & I'm close to cancelling all together. It's clearly amateur hour at BT.
4 REPLIES 4
Message 2 of 5
Re: Broadband Connection dropping continually
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Message 3 of 5
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ64643200
Firmware version:
SG4B10002244
Firmware updated:
07-Feb-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
Data rate:
9.99 kbps / 55.00 kbps
Maximum data rate:
33691 / 99315
Noise margin:
22.7 / 22.6
Line attenuation:
10.6
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
0 MB Uploaded / 0 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-672Z
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-672Z
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:66:92:F5
Software variant:
Boot loader:
7.33.1
Message 4 of 5
this is a customer help customer forum and your posts do not go to BT - the forum is monitored by the forum mods who are BT employees
you have max speed for infinity 1 but there is no conenction time - did you just rest router?
what is conenction time now - dsl uptime?
Message 5 of 5
There hasn't been a connection for most of the day. I had 30 minutes of connectivity at about midday then the connection dropped & the routers been unable to establish another one. If I restart it it goes from green to flashing orange, to solid orange. Occasionally it will flash purple then back to orange.
