@ivanbw wrote:
Ok, thanks, I will try that. Two questions:
1) I attach a photo of a filter I found in my house; I suspect it is several years old - is that sufficient, or would you recommend an alternative?
2) Is the Router Stats you refer to the "Event Log" I can see on my Smart Hub Manager?
Thanks.
That filter should be OK.
Event log is not stats. Go Advanced settings/technical log.
Hi @ivanbw and thanks for posting.
Sorry you’ve been having problems with the connection. We haven’t heard from you in a few days. Have you tried connecting with the filter? Has it made and difference? Can you post back and let us know how you’re getting on?
Cheers
David
